2014 Kia Forte Remote Start Install Pictorial
Forum Name: Car Security and Convenience - Alarm/Remote Start Pictorials
Forum Discription: Installer submitted Alarm, Keyless Entry, and Remote Start Pictorials from our Car Security and Convenience forum.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135901
Printed Date: April 30, 2024 at 8:40 PM
Topic: 2014 Kia Forte Remote Start Install Pictorial
Posted By: chev104275
Subject: 2014 Kia Forte Remote Start Install Pictorial
Date Posted: January 23, 2014 at 9:38 AM
This is a 2014 Kia Forte Regular Key
This car has no transponder. It has a intergrated remote with the key. The remote doesnt work when car is running.
The car has factory Anti-grind
I used a DEI 4103 and 1 Bosch relay for the trunk release
Disassembly
posted_image
   Left side dash cover is held in with Plastic clips Use a non marring tool to remove
posted_image
   There is 2 Phillps screws under the cover that hold in the left side of the dash
posted_image
    There is 1 phillps screw in the right side of the dash
posted_image
     The Metal is held in by 5 10mm Bolts
posted_image
     Turn the steering wheel to the left to expose 1 phillps screw
posted_image
     Turn the steering wheel to the right to expose 1 phillps screw
posted_image
    The bottom of the column shroud has 1 phillps screw
posted_image
    Overall fusebox view bottom right connector is where the locks,FAD,drivers door pin, The black clip hanging is where the hood pin wire is located
posted_image
     Drivers Door Pin (Brown) Pin 1 This was used with the rearm wire to shut down the auto lights
posted_image
    Factory alarm disarm (pink) pin 17
posted_image
    Lock Type B(Pink/Black) Pin 12
posted_image
    Unlock Type B (yellow/Black) Pin 3
posted_image
    Trunk release Fusebox Left side connector Pin 35 (this is the motor wire you will need a relay to invert the polarity if your unit doesnt have the capability)
posted_image
    Factory hood Pin Fusebox black 30 pin plug (D) (Green) Pin 15
posted_image
    Horn (white) at Clock spring connector
posted_image
    12 volts (green) Pin 1 Ingition Harness
posted_image
    12 Volts (red) Pin 5 Ingition Harness
posted_image
    Ingition (pink) Pin 4 Ingition Harness
posted_image
    Acc 1 (black) Pin 2 Ingition Harness
posted_image
    Acc 2 (Blue) Pin 6 Ingition Harness
posted_image
    Starter ( Green) Pin 3 Ingition Harness
posted_image
    Overall Ingition View
posted_image
    Brake theres a plastic shroud covering the end of the wires its comes right off with a few clips
posted_image
    Brake wire without the Shroud on it (gray)
posted_image
     Negitive Parking lights (pink) Pin 2 at light switch
Whats not shown is the ground Plenty of room in the kick panel for that and the Tach Any uncommon side of a coil or injector will work
Posted By: lucasoil4u
Date Posted: February 21, 2014 at 11:48 AM
I installed on one of these cars. If you lock the door via lock button on the door does the car unlock sith the aftermarket remote? Mine does not and im confused.
Date Posted: February 21, 2014 at 12:02 PM
Did you hook up factory alarm disarm pin 17 pink same connector as locks
I've had a few even without factory alarms do that hook up the disarm wire and it should fix it
Posted By: mjones1052
Date Posted: July 12, 2014 at 5:36 PM
Can you please tell me the tach wire or post a picture? I followed your guide and I seem to be hooked up. However, all the coils have a common blue wire and then each has a 2nd uncommon color. So, I went to cyl 3 and hooked to the uncommon and got nothing. I also hooked in to the brown alternator wire from the driver kick which I got from another site. Neither got me anything.
I'm getting 7 flashes on my Prestige APS901c which tells me tach not learned when I try to start it. When I follow the tach programming I get nothing with those 2 wire configurations.
Any help would be amazing. Just need to know a good tach connection in the cookpit somewhere as the uncommon didn't seem to work on the coils.
Posted By: long166
Date Posted: November 01, 2014 at 5:48 PM
Kia/Hyundai cars with factory alarm (07-14ish) you need to hit up the disarm and lock detection with the disarm diode isolated. That should make the keyless on the rs work.
Posted By: raulromo34
Date Posted: June 23, 2015 at 6:32 PM
have you installed alarm on 2014-2015 kia soul?
was wondering if the color codes are the same.
found a different site that showed lock as red (+), and unlock as yellow/black (-)tyoe b these wires at dash fuse box white 16 pin plug (b) pin 8 (red) and pin 3 is Yellow/black... then it shows lock motor wire as gray (5-wire type) I am confussed. usually most Asian vehicles are negative for door locks. maybe its just where they are getting the signal???? any help would help.. thanks Raul
football fanatic
Date Posted: June 24, 2015 at 6:52 AM
I have done quite a few souls.
Lock should be red (-) 16 pin plug pin 8
Unlock should be yellow/black (-) pin 3 same 16 pin plug
I've have never used the unlock detection wire. I use the factory alarm disarm wire pin 4 (-) pink same connector as locks. Even if your car doesn't have a factory alarm the wire will still be there. Tie the factory alarm disarm wire from you system to they pink and it should unlock everytime
Date Posted: June 24, 2015 at 9:40 AM
Thanks you.   I will be doing install this week on one. It makes sense that the lock wire would be
I was on the12volt .com website and someone
Posted that it's (+).
Thanks again in advance.
football fanatic
Posted By: jeanmaurits
Date Posted: April 02, 2017 at 7:11 PM
hello, i have to install a car alarm on a KIA Forte, can someone help me with information of wich wire is the wire for the fuel pomp.
let me know please.
jeanmaurits
Posted By: k9cuevas
Date Posted: July 28, 2017 at 11:10 AM
This information was excellent. Three questions for you.
1- I have a 2011 Forte and I have to put a relay in on the accessory wire/heater blower due to starter grind on key take over. Do you have information on how to wire in the relay? Which wires go to which?
2- I installed a Directed Electronics (Viper) 4105V and none of the wires on the remote start list anything for dome light. Is there another wire I am supposed to hook up for illuminated entry?
I did not hook up the factory disarm. The previous remote start that was in here did not have it hooked up either. The car remotes starts, locks, unlocks, and operates as it should. Do I still need to connect that wire? If so where do I get a diode and how does that work?
Thanks again for all the info.
Orlando C.
