BOAT RADIO HOOK UP
Forum Name: Marine Electronics
Forum Discription: Boat Stereos, Security, Navigation, Lights, Switches, Gauges, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33909
Printed Date: May 15, 2024 at 12:25 AM
Topic: BOAT RADIO HOOK UP
Posted By: Legrones
Subject: BOAT RADIO HOOK UP
Date Posted: June 15, 2004 at 8:31 AM
HI DOES ANY ONE HAVE A PAGE OR GOOD INFO ON PUTTING A RADIO IN A 19 FOOT BOAT .IT DOES NOT HAVE ONE KNOW SO IT WILL BE A CUSTOM JOB BUT JUST THINKING DO U HOOK IT UP TO IGN WIRES LIKE A CAR OR NOT ?
Dale / Cory
Posted By: unc2003
Date Posted: June 15, 2004 at 9:19 AM
I've honestly never hooked one up in a boat, but it seems to me that all the same principles would apply.  Need 12V Constant, 12V Ignition, and Ground, and then your speakers.
Before you judge someone, you should first walk a mile in their shoes. Because then your a mile away, and you have their shoes.
Posted By: Chad7n7
Date Posted: June 15, 2004 at 1:36 PM
I have done some with constant +12V and switched +12V ran directly to the positive side of the battery, and ground to the negative side, If done like that, you have to turn the radio on and off manually.
I have also done some, depending on accessories, by getting a switched +12V from another accessory, and that will work, And in some newer boats, even though there is no HU installed, in the fuse panel you have terminals for a HU.
Hope this helps. Good Luck with your install
Posted By: kgerry
Date Posted: June 15, 2004 at 1:49 PM
just did an install in a 19' Sea Ray this weekend....same as a car except i ran power AND ground right from the battery for the amps. Power to the HU came thru an Aux switch on the dash switch panel... quite simple actually
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
