Boat Stereo
Forum Name: Marine Electronics
Forum Discription: Boat Stereos, Security, Navigation, Lights, Switches, Gauges, etc.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57297
Printed Date: May 15, 2024 at 12:44 PM
Topic: Boat Stereo
Posted By: Kylemc20
Subject: Boat Stereo
Date Posted: June 08, 2005 at 2:12 PM
I was just wonding what is the best way to wire my boat to put a cd player in. I have an old alpine CDM-7874. The boat now has no speakers and wireing for speakers. Any input would help... Thanks
Posted By: Francious70
Date Posted: June 08, 2005 at 4:21 PM
Run a fused wire from the battery and connect it to the pos(ignition/red wire) and the acc(yellow wire). The run a ground batter directly to the battery.
Run speaker wires as normal. Just make sure you have marine equiptment. If you only have regular speakers, get a baffel for the back of the speaker.
Paul
Posted By: Asmodeus
Date Posted: June 09, 2005 at 9:27 AM
Memphis Car Audio has put out a great line of Marine Amps, Speakers & Subwoofers...There is a set of 8" Coaxials that sound AMAZING....BUT they do require a little more wattage than your average CD player will put out...
Everything on the marine line sounds great and is very water resistent....My shop has blown up with people wanting systems on their water craft...I love it...
posted_image
Making the World A Louder Place
Posted By: thepencil
Date Posted: June 09, 2005 at 10:45 AM
Addition note, you can run the +12V constant to the battery. On the switch wire (REMOTE WIRE) you can add a toggle switch in between which will give you the options of turning off the stereo when you don't want to listen to it any more.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
