2008 grand caravan remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100192
Printed Date: May 01, 2024 at 2:20 PM
Topic: 2008 grand caravan remote start
Posted By: audiomaninc
Subject: 2008 grand caravan remote start
Date Posted: December 18, 2007 at 7:11 PM
Hey there! I'm going to attempt a starter in a 2008 Grand Caravan tomorrow, using an Omega Mars11, and an Omega IM06 transponder bypass with SICH1 0.02 firmware. Has anyone attempted one of these vehicles yet? The manual for the bypass tells me to take apart a module at the ignition barrel and solder wires directly to the board. I'm just looking for some advice before I jump in. Thanks! -Jason @AudioMan
Posted By: techman93
Date Posted: December 18, 2007 at 7:52 PM
Test to see if you need a bypass first because you may not need it. It will have a second starter multiplex that you will need to isolate through a relay and 180 ohm resistor. If you need diagram let me know.
------------- The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Posted By: tonyberg
Date Posted: December 18, 2007 at 7:56 PM
eh the 08 caravan is a whole new ball of wax bud...its easy..just follow that diagram that comes with the SICH firmware...be careful soldering on the board....there are no resistors in an 08
Date Posted: December 19, 2007 at 5:39 PM
Got it installed today, but a few issues. Followed SICH diagram, everything connected inside ignition baril. When RS is activated, there's a ding, like the key is in the ignition, but none of the lights on the dashboard turn on, or the accessories. Double checked everything is still intact inside the ign. Also, can't find the brake wire, or parking lights. The only tech sheet I have is from Code Alarm, and it's pretty sparse to say the least. Please help! Jason
Date Posted: December 19, 2007 at 6:46 PM
Battery LIGHT BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 PINK/WHITE (+) IGNITION SWITCH HARNESS
Parking Lights WHITE/ LIGHT GREEN (L) & WHITE/ TAN (R) (+) AT TIPM MODULE ON DRIVERS SIDE OF ENGINE
Brake Lights WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Horn DARK GREEN/ VIOLET (-) IN HARNESS AT STEERING COLUMN
Power Unlock VIOLET/DARK GREEN (-) IN HARNESS TO DRIVER DOOR IN DRIVER KICKPANEL
PowerLock VIOLET/DARK GREEN (-) IN HARNESS TO DRIVER DOOR IN DRIVER KICKPANEL
this per audiovox site
no other notes on it
Posted By: racing_bidule
Date Posted: December 19, 2007 at 7:40 PM
This vehicle takes less then 1:30h using an iDataLink module. It takes care of everything, why would you use the hard way with these vehicles. The iDataLink module is taking care of the whole ignition cycle (the way the ignition is cycled is critical on these vehicles) the bypasskit relies on the remote starter ignition cycle which will not work wit every remote starters. starts at page 13 https://www.idatalink.com/store/viewDoc.php?id=79 ------------- If you fail on your first attempt, at least destroy all evidence you tried!
Posted By: tonyberg
Date Posted: February 22, 2008 at 7:59 PM
We just switched over to the ADS-AL-CA module as the main one that we stock, and I must say its great. We utilized one today on a 2008 Grand Caravan SXT. The only thing I disagree with is taking apart the wireless ignition module. They state in the directions that if you solder onto the pins underneath the cover that you will not be able to separate the circuit boards....but there is absolutely no need to ever separate the circuit boards, these modules are not serviceable and can only be ordered as whole pieces. My recommendation is to solder to the pins that you can see when you remove the access panel.
Posted By: Velocity Motors
Date Posted: February 23, 2008 at 8:53 AM
I have not had the opportunity to install into a new Caravan yet, do you have pics of what you are talking about ? Thanks ------------- Jeff
