07 express/savana security light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100267
Printed Date: May 15, 2024 at 12:03 AM
Topic: 07 express/savana security light
Posted By: kraylon
Subject: 07 express/savana security light
Date Posted: December 20, 2007 at 6:11 PM
i just installed a remote start (avital 4200) and every thing went great till i got to the passlock II immoblizer, I used a 555l. the wire that go in to the plug on top of the key cylinder were yellow, ORANGE / white and tan. i have the yellow from the 555l to the key side of the yellow and the BLACK / YELLOW from the 555l to the non key side the i have the black wire from the 555l to the ORANGE / white and the vechile starts and remotes starts just fine but the security light stays on all the time and i can' figure out what i did wrong anyone have any ideas?
Posted By: Twelvoltz
Date Posted: December 20, 2007 at 6:39 PM
Did you solder your connections? If you used crimp connectors they can introduce a small amount of additional resistance. It may be close enough to start the vehicle but still trip the light. Try turning the key to the run position and leave it there for about 10 minutes, this will teach the vehicle the current resistance and should turn the light off.
------------- Installer, IT support, and FFL. I need less hobbies.
Posted By: kraylon
Date Posted: December 20, 2007 at 10:56 PM
all connections are soldered is it possable that i need to hook the black wire from the 555l to the tan wire instead of the ORANGE / white
Posted By: StealthEs
Date Posted: December 20, 2007 at 11:27 PM
Doesn't that car have a passlock 3? I'm sure it does, you need a 457GW to get rid of the light, or , you can use a Idatalink mod as well.
------------- Cris
Posted By: kraylon
Date Posted: December 20, 2007 at 11:35 PM
according to directed.com it has passlock II
Posted By: kraylon
Date Posted: December 20, 2007 at 11:38 PM
what is the idatamod?
Date Posted: December 20, 2007 at 11:44 PM
It's a Data wire based bypass. Check them out on Idatalink.com
------------- Cris
Posted By: kraylon
Date Posted: December 21, 2007 at 2:34 AM
is there a more detailed diagram on the immobilzer unit?
Posted By: kraylon
Date Posted: December 21, 2007 at 3:54 AM
i think i have done one or 2 things wrong 1) is i used the black wire from the 555l needs to be on the tan wire not the ORANGE / white or 2) i need to hook up the keysense wire but i have never ever hooked one up before
Posted By: NowYaKnow
Date Posted: December 21, 2007 at 5:35 PM
Correct the tan is your passlock ground you should not be hooked to the ORANGE / white.
