remote starter, 05 ram 3500 diesel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=100288
Printed Date: June 04, 2024 at 12:10 AM
Topic: remote starter, 05 ram 3500 diesel
Posted By: aziegler
Subject: remote starter, 05 ram 3500 diesel
Date Posted: December 21, 2007 at 1:09 AM
Hi All, New member, first post, kind of nervous:-) **Awsome Site !!!** I have an 05 ram 3500 diesel, auto that I am going to install a remote start into. The make/model is an Autopage rs727. I used to have an off brand remote starter in it a couple years ago. I removed it for two reasons, distance was to limited, and I installed it to use the voltage sensing instead of the tach sensing. I could not convince myself tap into the wire next to the ECM at the lower front of the motor for fear of the moisture etc corroding the wire and causing problems. The voltage sensing worked when the weather was warm. When it got cold (Alaska) the glow plugs would kick on repetitively and the unit would see the fluctuation of voltage and shut of the motor just to restart it 20 second later. Not a good situation to repeat this cycle over and over until the engine warmed to the point where the glow plugs stops cycling on. After another winter without it I have decided to install this better unit and tap into the tach wire if needed. I would like to know if there are any other location I can pick up the or a suitable signal for this unit. If I must go tot he PCM for the tach signal, which wire would it be, and is there a preferred way to protect it from the harsh environment? Are there any other trick I should know about this model of remote starter? THX, Andy
Posted By: KarTuneMan
Date Posted: December 21, 2007 at 10:11 AM
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | 12 VOLTS | Red (2 wires) | Ignition harness | + | IGNITION | Pink/white | Ignition harness | + | IGNITION 2 | Pink/green | Ignition harness | + | ACCESSORY | Blue (large gauge) | Ignition harness | + | ACCESSORY 2 | Pink / YELLOW | Ignition harness | + | | | There are 2 wires of this color and one of them turns off the ABS light on remote start. You will need to test both. |
| STARTER | Yellow | Ignition harness | + | KEY SENSE | Violet/tan | Ignition harness | - | TACH SIGNAL | SEE NOTES | | | | | On the 5.2L and 5.9L engines, the Tach wire can be found at the coil on the engine near the distributor. Program you cylinder setting according to the number of cylinders. On the 8.0L V10 engine there are 2 coils packs on the right side of the engine. Use the BLACK/ GRAY at the 6-pack for a 2 cylinder reference. |
| DIESEL TACH SIGNAL | Dk.blue/gray | On C1 plug at ECM | AC | | | The ECM is located on the lower driver's side of the engine. The C1 connector is the plug closest to the radiator. |
| FUEL INJECTOR | Opposite from Dk.GREEN/ orange | At any injector on engine | AC | LOCK | Violet/blue | At harness to rear in driver's kickpanel | - | | | One wire system. Use a ground pulse through a 470-ohm resistor to disarm factory security (a second pulse will unlock the doors. A ground pulse through a 2-kohm resistor will arm security and lock the doors. See the door lock diagram for details. |
| UNLOCK | Violet/blue | At harness to rear in driver's kickpanel | - | | | One wire system. Use a ground pulse through a 470-ohm resistor to disarm factory security (a second pulse will unlock the doors. A ground pulse through a 2-kohm resistor will arm security and lock the doors. See the door lock diagram for details. |
| GLO-PLUG SIGNAL | DATA ONLY | USE DELAY TIMER | | DOORPIN | SEE NOTES | | | | | Violet (driver's door) & Violet/white (rear left door) both found in a harness on the left side of the brake pedal. Violet/white (pass. Door) & Violet / YELLOW (rear right door) both found in passenger kick panel. |
| FACTORY ARM | Arms with lock wire | | | FACTORY DISARM | Disarms with unlock | | | BRAKESWITCH | WHITE/ tan | At switch above brake pedal | + | PARKLIGHTS | WHITE/ lt.green | At light switch harness | - | | | Ground this wire through a 330-Ohm resistor to activate parking lights. The wire should be openned with a relay to prevent feedback to the switch. See the diagram. |
| HORN | Dk.GREEN/ violet | At steering column | - | VSS WIRE | Dk.GREEN/ YELLOW | At PCM pin C1-13 | | DATABUS INTERFACE | Pin-2(top row from left) | Diagnostic plug below dash | DATA |
Set your unit to "wait to start" for 30 seconds. -------------
Posted By: ralphtonka
Date Posted: December 21, 2007 at 1:06 PM
glow plug @solenoid below air intake on pass fender. remove 14awg wire, test w/ key off to on will read 12v, or open if heated intake not required (engine is already warm) cant remember wire colour. on 06+ it is brown yellow
Date Posted: December 21, 2007 at 9:16 PM
If you just set a timer.... if the unit has one, no connection is needed for the glowplug. It will start everytime, hot, or cold.
Date Posted: December 21, 2007 at 10:15 PM
just metioned glo plug cuz he is form Alaska
Posted By: aziegler
Date Posted: December 22, 2007 at 12:07 PM
Thanks guys, I like the glow plug wire use method. My previous starter used the timer method. When it was really cold it did not waite long enough for the glow plug to cycle off. The chart from KarTuneMan shows to use the ECM wire for the tach signal. DIESEL TACH SIGNAL | Dk.blue/gray | On C1 plug at ECM | AC | | | The ECM is located on the lower driver's side of the engine. The C1 connector is the plug closest to the radiator. Is this the only location to pick up an appropriate signal. On these Rams the ECm is in a very bad location for tapping into. I would prefer to use a different source if possible. Also if I need to use the ECM wire, how best to protect the connection from the elements? Thanks, Andy |
Posted By: Velocity Motors
Date Posted: December 23, 2007 at 1:35 AM
Use the cam sensor at the front of the engine at the lower portion of the fan. The wire will vary according the the truck but I've had GREY/BLUE and also TAN / YELLOW for the wire colors. There are only 3 wires at this connector so you can use the trial and error method.
------------- Jeff
Posted By: another-kelly
Date Posted: December 23, 2007 at 12:58 PM
DITTO. much easier than sifting through that huge harness with no slack the ecm
Posted By: aziegler
Date Posted: December 25, 2007 at 9:22 PM
Thanks for the infor so far. KarTuneMan: I did not know what you ment by "set the timer". My previous starter did not have this option. I got the unit running this afternoon with the timer method. The AutoPage 727 is not the friendliest unit to program. I am looing for a little more detailed information on the Lock/Unlock circuits and the driving light circuit. The Lock trigger is a single negative pulse through a 2Kohm resister for luck, and the unlock is a double pulse through a 470 ohm resister. I'm assuming that a relay is not required for these circuits and if I buy these resistors it should work installed directly inline. I am looking for a more detailed diagram or description of what is required over what is available in the instructions. The programming options for the Lock/Unlock are***** 1) 0.8 second door lock & unlock ***** 2) 3.5 second door lock & unlock ***** 3) 0.8 second lock, 0.35 second unlock****** 4) 0.8 sec. dbl lock, 0.8 sec. dbl unlock. What would be required for my vehicle? On the parking light I have the correct WHITE/ green wire at the switch location, do I need to install a relay on the -trigger before the target wire? If so, how do I wire a relay for a negative trigger circuit? Thanks, Andy
Posted By: tedmond
Date Posted: December 25, 2007 at 10:39 PM
Program you unit to do: 4) 0.8 sec. dbl lock, 0.8 sec. dbl unlock this is the only one i see that does double pulse. 1) The Lock trigger is a single negative pulse through a 2Kohm resister for luck, and the unlock is a double pulse through a 470 ohm resister. I'm assuming that a relay is not required for these circuits and if I buy these resistors it should work installed directly inline. i have done that befor on a prostart unit for a mazda. didnt bother using a relay and it works fine. make sure it is the trigger wire for the lock/unlock relay. if u grab the wrong wire such as the actuator, you will toast ur unit nicely. 2) On the parking light I have the correct WHITE/ green wire at the switch location, do I need to install a relay on the -trigger before the target wire? If so, how do I wire a relay for a negative trigger circuit? 85 - Ground 86 - parking light output from starter (+) 87 - Ground (high current) with 330 ohm resistor inline. 87a - cut parking light wire, connect from Lamp Switch Side. 30 - to parking light wire (end that is cut - car side) diode across 85 and 86, white band (cathode) on 86.
Posted By: aziegler
Date Posted: December 27, 2007 at 9:53 PM
Thanks for the responses, Put together I was able to figure our the lock & unlock circuits. The directions for the Autopage rs727 for the resistor size did not work on my vehicle. With some experimenting I found that a 1Kohm lock and 33ohm unlock through relays worked. The parking light also worked with a 330ohm resistor through a relay. I have a couple remaining issues that I would like to figure out. The instruction state that the dome light needs to be connected for the alarm to function. There is n reference for the dome light wire in the data sheet. Does anyone have any information on the location/color of this wire?
Date Posted: December 28, 2007 at 10:52 AM
try
Date Posted: December 28, 2007 at 10:53 AM
sorry, try brown in dr a pillar
Posted By: paul h
Date Posted: January 10, 2008 at 11:51 PM
azeigler....did you get all your stuff figured out?? I am working the exact truck and exact model RS as you did.....any info you have would be awesome!! Particular....how did you wire all the dang ignition and acc wires for the truck?? I'm sure through some relays...but how did all yours come together and how is it working out for ya?? Thanks.
Posted By: aziegler
Date Posted: January 11, 2008 at 12:52 AM
Hi Paul, I believe our RS727 had two ignition and two accessory leads. The ignition I hooked up according to the data sheet from AutoPage. The first accessory wire was also hooked up according to the data sheet but for the second accessory wire I used an old modified test light with +12 volts on it and I probed the remaining pink wires with the heater fan on high until I found the correct one that activated the fan. That is where I hooked the second accessory wire. It has been working great. I know you will hear not to jumper your accesory wires together. I used to have a different RS in this same truck and that is what the previous manufacturer recommended and that is the way I ran it for over a year with no issues. If you PM me your email address I will send you the data sheet and the light and door lock documents from Autopage. AZ
Posted By: tedmond
Date Posted: January 11, 2008 at 8:37 AM
paul h, autopage units have alot of outputs that are easily configurable (known as fifth relay). With the placement of a jumper, you can program the unit to do acc, ignition or watever.
