LOL -- they actually soldered the 1st and 2nd starter wires? (a.k.a "jumping" two wires)
Technically this is incorrect to do, after extensive discussions about Nissan and other vehicle makes 1st and 2nd starter wires, many decided that these two circuits must be electrically isolated. I would un-do what they did and use an SPDT relay to relay power to the second starter wire via a positive trigger from the 1st starter wire. Here's the diagram I would use:
Trnk Release PINK/BLACK (-) IN HARNESS IN DRIVERS KICKPANEL
Remote Start
WIRE COLOR POLARITY LOCATION
Battery WHITE/ RED (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
Ignition 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
Starter 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type TRANSPONDER
Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
Key Sense BLUE/WHITE (+) PIN-32 AT SECU
Tachometer RED (-) AT IGNITION COIL
Speed Sense VIOLET/RED (AC) IN HARNESS UNDER CENTER CONSOLE
Parking Lights RED / BLUE (+) AT VEHICLE FUSE PANEL
Brake Lights RED / GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Horn WHITE/ GREEN (-) PIN-19 AT SECU
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock VIOLET/RED (-) IN HARNESS IN DRIVERS KICKPANEL
PowerLock GRAY (-) IN HARNESS IN DRIVERS KICKPANEL
Driver Mtr Unlock YELLOW (+) IN HARNESS TO RIGHT OF STEERING COLUMN
Driver Mtr Lock RED / YELLOW (+) IN HARNESS TO RIGHT OF STEERING COLUMN
Pas Mtr Unlock PINK/BLACK (+) PIN-14 AT SECU
The search function is your friend.
