remote start not working, 91 chevy van
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101133
Printed Date: June 04, 2024 at 12:12 PM
Topic: remote start not working, 91 chevy van
Posted By: donerite
Subject: remote start not working, 91 chevy van
Date Posted: January 13, 2008 at 11:08 PM
I have 91 chev van (starcraft convertion ) it has viper alarm and remote start. It is about 7years old . Everthing works alarm wise . When i try remote start it goes through all the motion ( dash lights up engine light comes on and just sits there . the starter does not engage or turn on . Could it be the hood sensor ( safty senser that stop engine from cranking remotly when open . How can i bypass it temparatly .
Do you think this is what it could be . It is rusty >
there is also a but under dash to push when setting remotes and what ever
thanks
Posted By: dmielken
Date Posted: January 14, 2008 at 9:59 AM
Usually if the hood pin is faulty or damaged, the vehicle will not engage the remote start, so the fact your ignition comes on would mean that the problem lies elsewhere. If you want to check and see if it is the hoodpin, you can temporarily disconnect it. There is usually a female disconnect clipped on the bottom of it. If it remote starts, then you need to have the hood pin replaced.
Another item to check is to make sure the vehicle is not in Valet mode and that the safety switch (if installed) is not set to the "OFF" position. If the vehicle is in Valet mode, the LED from the Viper will be solid red. And the safety swtich will be a small toggle style switch with a red handle.
Posted By: donerite
Date Posted: January 14, 2008 at 12:00 PM
if it is safty mode how would i remove it . It does have the valet button I cant remember what to do to use it. I think you put the key in turn on key and while pushing valet butten .or somthing like that how far off am i
any help would be great
thanks
Posted By: ralphtonka
Date Posted: January 14, 2008 at 6:19 PM
one of the 30 amp fuses is blown if ign comes on but no acc or crank, replace fuse and leave your rear blower on low or off and front on 1/2
Posted By: donerite
Date Posted: January 15, 2008 at 2:57 PM
where is the fuse located . how would i trace it
would it be high up in dash where you have to take dash apart
Date Posted: January 15, 2008 at 4:57 PM
probably under dash on driver side should be close to relay pack that will start clicking when you try to activate rs
