2004 chevy colorado, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101403
Printed Date: June 14, 2024 at 2:05 AM
Topic: 2004 chevy colorado, remote start
Posted By: 308m99
Subject: 2004 chevy colorado, remote start
Date Posted: January 20, 2008 at 6:22 PM
having some difficulty with my install.i can get the truck to remot start,but dies after 5 seconds or so. also don't have any accesories working(heater,dash lights etc...)so i'm not sure if i have everything connected correctly.at first i had trouble setting dip switches on bypass and it would immediatly set off tamper mode and have to wait for system to reset itself.notsur if there is a second ign. wire i need to hook up or what exactly my proplem is if anyone is familiar with these trucks and correct way to set up remote start please share some insight.thanks in advance
Posted By: GregK
Date Posted: January 20, 2008 at 6:37 PM
The bypass modules with dip switches aren't reliable at all.
Go with an Xpresskit XK06 or PLJX or an idatalink ADS-DL that has the proper firmware loaded on it.
Here is the wiring for the vehicle:
12 VOLT CONSTANT GET THE 12VOLTS FROM VHICLES BATTERY ONLY @ BATTERY ONLY
STARTER not used! See NOTE *1
IGNITION 1 WHITE/ GREEN to DARK BLUE (+) IGNITION SWITCH HARNESS
IGNITION 2 See NOTE *1
ACCESSORY /HEATER BLOWER 1 WHITE/ RED to BROWN (+) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) BROWN / WHITE (-) @ BCM, GRAY Plug, Pin A7, See NOTE *4
PARKING LIGHTS ( + ) BROWN (+) @ BCM, BLACK Plug, Pin A48, See NOTE *4
POWER LOCK LIGHT BLUE (TYPE B) @ BCM, BLACK Plug, Pin A11, See NOTE *4
POWER UNLOCK DARK BLUE (TYPE B) @ BCM, BLACK Plug, See NOTE *4
LOCK MOTOR WIRE GRAY (+) @ DOOR LOCK SWITCH in DRIVERS DOOR
DOOR TRIGGER See NOTE *2
DOMELIGHT SUPERVISION WHITE to DARK GREEN / WHITE (-) @ BCM, BLACK Plug, Pin A46, See NOTE *4
HORN GREEN to BLACK (-) @ BCM, GRAY plug, Pin A25, See NOTE *4
TACH ANY wire that is NOT PINK or BLACK @ any IGNITION COIL or FUEL INJECTOR
WAIT TO START LIGHT
BRAKE LIGHT BLUE (+) @ STEERING COLUMN HARNESS
ANTI-THEFT GM'S NEW PASSLOCK 2 ANTI-THEFT System
NOTES
NOTE *1 This vehicle requires a special PASSLOCK 2 Bypass module
NOTE *2 This vehicle has (4) door trigger wires the GREY/BLACK (-) is used for the DRIVERS door Pin A32, the PASSENGER door is a LIGHT GREEN/ BLACK (-) Pin A38, the DRIVERS REAR door is a LIGHT BLUE/BLACK (-) Pin A39 and the PASSENGERS REAR door is a BLACK/ WHITE (-) Pin A39 all are located at the BCM's BLACK Plug. When connecting to an ALARM SYSTEM use all 4 and DIODE ISOLATE.
NOTE *3 this vehicle uses the NEW PASSLOCK 2 ANTI-THEFT System
NOTE *4 the BCM is located in the PASSENGER KICK PANEL.
------------- GDK Electronics
Home theatre & mobile electronics installations
Winnipeg, MB
Posted By: 308m99
Date Posted: January 20, 2008 at 7:11 PM
maybe my troubles are the bypass then.as i tied my access.,heater, wire from r/s to the WHITE/ red wire;my ign #1 to WHITE/ green;pulled 2 sources of +12volt from batt(heavey gauge wires on r/s unit)but also pulled 12 volt+ from WHITE/ black wire in ign harness.is ther a need for 2nd ign anywhere?thanks GregK
Posted By: GregK
Date Posted: January 20, 2008 at 8:53 PM
The bypass module will take care of any connections not listed in the wiring chart.
Winnipeg, MB
Posted By: 308m99
Date Posted: January 21, 2008 at 3:29 PM
thanks again GregK,i will look into the PLJX modual and hopefully that will take care of things
Posted By: collyn eastham
Date Posted: January 21, 2008 at 8:28 PM
Just use two relays, one diode, and the correct resistor value. I did this on a H3 yesterday and they are almost identical trucks electrically. Basically you start the vehicle, then cut the resistance wire and then measure to the reference wire while cranking the vehicle (truck has anti-grind, so dont worry about hitting the starter while its running). Then, using two relays you need to unlatch acc and use the second relay to insert the correct resistance to disable theft system. The trucks starter begins when ignition is 12+ and acc is 0.
------------- Collyn Eastham
a.k.a. 300MBQuart
08 HHR Panel
Posted By: techman93
Date Posted: January 21, 2008 at 11:48 PM
that is the way I do it at my shop I work at with no problem on canyons, colorados, and H3 ------------- The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Posted By: 308m99
Date Posted: January 22, 2008 at 7:19 PM
i had some difficulty measuring the resistance,actualy reading the correct ohm value.i think my mult-meter was set at 2K ohms setting and got a reading of .372 and thought initally that meant 372 ohms,??.never really tested anything of this nature before so not real sure if that was correct or i had made wrong connections or what was going on.hit remote,truck would start but had no dash lights/heater and would shut off a few seconds later.at any rate,i ordered a PLJX self learning bypass kit and should have it on 1/23 or 1/24,so i will try that and hopefully get my R/S installed on saturday.thanks to all that have shared info and if any one could elaborate on the ohms deal,maybe i could get a better understanding of that for the future>
Date Posted: January 22, 2008 at 11:04 PM
to test you cut wire after truck is running. Put negative test lead on the reference wire in ignition harness and the positive lead to the side of wire you cut going to key cylinder. Then turn key as to start and hold, starter will not grind because there is a factory anti grind built into these trucks. Measure resistance at lowest and work your way up, auto ranging meter will do this automatically. See what you get for value and see what range you are in. You may have gotten a false reading the first time you did this so you may want to start from scratch on the ohms part. WHITE/ blue is cut and WHITE/ yellow is reference.
Posted By: 308m99
Date Posted: January 23, 2008 at 4:56 PM
so depending on what range the meter is set to what is the value???cause at the lowest setting it over ranged it,next setting got the .372 reading(2K setting i believe)next setting got .37 and the next setting gave me .3.not very familiar with measuring ohms so i am not sure what the reading i get actually means
Date Posted: January 25, 2008 at 12:59 AM
So that is with cutting the wire and turning key to start position and holding it there to get a reading.
Posted By: 308m99
Date Posted: January 25, 2008 at 2:36 PM
that's correct techman93,wire cut and key in crank position
Date Posted: January 25, 2008 at 9:52 PM
I have not gotten a reading like that before. Had you kept that setting and try testing some resistors and see if you can get within 10% of that. That is what you should try.
Posted By: 308m99
Date Posted: January 26, 2008 at 4:59 PM
well,got it straightend out today.resistance reading was indeed 372 ohms,but i had cut wrong wire,cut the WHITE/ yellow instead of WHITE/ blue.so i have my dip switches set to 381 ohms and everything is fine now.got the door lock/unlock wired up so that part is operational as well.just need to double check parking light wire so i can connect that.overall very pleased with this R/S unit.forget the model # but it is made by valiant.(ordered from j.c. whitney for $56)has 1,000FT range,keyless capable,l.e.d light to show its operating.think i will order a 2nd unit to upgrade the one in my wifes van.current one is a basic R/S w/400ft range(bulldog security)a BIG thank you to techman93 and gregk for their help and insight with this project.thanks again guys
