2008 c300 mbz
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101412
Printed Date: June 02, 2024 at 5:59 PM
Topic: 2008 c300 mbz
Posted By: stevet
Subject: 2008 c300 mbz
Date Posted: January 20, 2008 at 10:04 PM
Any wiring diagrams on these cars yet????? Would a 07 be the same??? I suppose it would be a keyless ignition huh?
Anything?
Posted By: KarTuneMan
Date Posted: January 21, 2008 at 9:06 AM
Howie....you got any info on this car? Howwwwwie, are you there?
Posted By: Velocity Motors
Date Posted: January 21, 2008 at 9:22 AM
All new Mercedes vehicles are equipped with a Lazer Key or Cardpass system. Current no bypass module is currently available to install remote start. Is it a RS or is it an alarm system that you installing ?
------------- Jeff
Posted By: stevet
Date Posted: January 22, 2008 at 1:47 PM
Actually I'm installing a tracking system that interupts the starter circuit. Just need location of 12v+, ignition and starter wire that can be interupted.
Posted By: howie ll
Date Posted: January 22, 2008 at 2:17 PM
Starter wire, only pick it up in engine bay fuse box, be very very careful how you test and from where you pick up, you would be safer in rear, go to battery, there is an ign in one of the trunk looms, remove light fitting and shove your antennae under bumper, break fuel pump relay low current feed.
