intelliguard 950 wiring needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101429
Printed Date: April 06, 2026 at 5:43 AM
Topic: intelliguard 950 wiring needed
Posted By: markmills2000uk
Subject: intelliguard 950 wiring needed
Date Posted: January 21, 2008 at 2:18 PM
anyone have a wiring diagram fro an intelliguard 950, my unit is second hand so i have not got a clue what goes where,
also how am i going to figure out the 8 all black wires that come out the side,i have figured out they are for the ignition and when i take the cover off the alarm they are numbered 1 to 8 but apart from that there no no markings,
jope someone can help,cheers guys
Posted By: howie ll
Date Posted: January 22, 2008 at 2:31 PM
Go to the Clifford website and download instructions
Posted By: howie ll
Date Posted: January 22, 2008 at 2:36 PM
Actually you wont be able to get it unless you are in the trade, the 8 wires are 2 x ground, ignition in and out, starter in and out, 20amp flasher lamp supply and main 5amp power supply. If you had a Wiz programme, a DMM and some tech knowledge you could work it out. That's how we do it when we have to install a previously removed machine that wasn't removed by ourselves.
