bulldog deluxe 500 remote problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101703
Printed Date: April 13, 2026 at 4:21 PM
Topic: bulldog deluxe 500 remote problems
Posted By: epb2001
Subject: bulldog deluxe 500 remote problems
Date Posted: January 30, 2008 at 7:50 AM
Hi folks. New poster that's having some issues with my remote starter and stumbled upon the forum. My issue is with the Bulldog Deluxe 500. Specifically, I'm having a problem with the remote. The starter button on it no longer works. Every other button is fine, but when I hit the one button that needs to work, the remote doesn't beep and nothing happens.
Just curious if anyone has had a similar issue. I'm guessing the remote's junk and I'll need a new one, but I figured I'd see if anyone else had any suggestions before I blow $50 on a new one.
Posted By: i am an idiot
Date Posted: January 30, 2008 at 8:00 AM
Have you taken the remote apart and checked for broken solder joints? If it does not have a mechanical switch on it remove the rubber pad from the top of it and clean the pad in warm water and clean the contacts on the board with a pencil eraser. Do not put the board in the warm water. Only the rubber pad, and dry it completly before reassembling it.
Posted By: brcidd
Date Posted: January 30, 2008 at 8:14 AM
You can buy replacement remotes for as little as $15 - you'll have to program it to your "brain box" anyway-- do a google search
------------- Brcidd - Engineer That Does Remote Starter Installs on the side.
Posted By: dea,can
Date Posted: January 30, 2008 at 6:38 PM
https://www.directwholesale.net/secure/ at top of the page type in search bar A705B ------------- dragon
