autostart as1584sh
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101918
Printed Date: May 10, 2024 at 5:15 AM
Topic: autostart as1584sh
Posted By: pipodayo
Subject: autostart as1584sh
Date Posted: February 05, 2008 at 8:14 PM
Hi !
I have an autostart AS-1584SH installed on my Subaru Forester 2003 . I lost and re-buy an used remote (FCC ID = NAHRS5304) that I can't program because I don't have the install guide . This starter model is not on the Autostart website and I can't get help from them (tried email and phone...) . So my question is : do you know how to program the remote ? Maybe someone has the install guide pdf ?
thanks for helping a newbie !
Posted By: Twelvoltz
Date Posted: February 06, 2008 at 3:14 PM
Most of the DEI products that I install follow the same procedure for programming new remotes. Maybe Autostart is the same?
Autostart has their manuals listed on their site. Here. They however do not specifically list the model number you list. I read through a couple of their manuals and they all listed the same procedure for programming a remote:
How to Program the Transmitter.
1. FLASH the Hood Pin Switch.
Before the 20 seconds have passed, turn the Ignition Key to the IGNITION ON (RUN) position.
Turn the IGNITION to OFF.
2. Press and hold the LOCK button until the vehicle gives 5 flashes. The Module has
stored the Transmitter in its memory.
3. Close the Hood, to exit.
Give it a shot
Posted By: pipodayo
Date Posted: February 06, 2008 at 7:10 PM
thanks for the link but my model (1584) is not listed :(
It seems that my car doesn't have a hood pin switch . I checked on the autostart module and didn't find it .
I found a 'valet' switch inside but it doesn't seem to work .
Posted By: dea,can
Date Posted: February 06, 2008 at 11:40 PM
posted_image
dragon
Posted By: dea,can
Date Posted: February 06, 2008 at 11:41 PM
posted_image
dragon
Posted By: pipodayo
Date Posted: February 07, 2008 at 12:25 PM
ok thanks for the tip . Is it possible that I don't have a hood pin switch ? because I really can't find it !
Posted By: red85
Date Posted: February 08, 2008 at 6:44 PM
Reach under the dash and find the 5 wire medium harness on the Autostart unit and grab the grey wire.  Ground it through a switch (any NC momentary switch will do).  Once your switch is connected, just follow the flash procedure and you'll be fine.  I have done this dozens of times with a spare hood pin switch that I keep in my toolbox with a long test lead on it.
Posted By: red85
Date Posted: February 08, 2008 at 6:54 PM
Just in case here's the procedure to flash the pin.  Hold the switch open for 5 seconds.  Release it and then open the switch briefly.  Your park lights should come on.  You are now in programming mode.  The key to run and then shut it off and remove the key.  Hold the lock button on the remote until the lights flash.  remove the ground.  Now you're done.
Posted By: pipodayo
Date Posted: February 27, 2008 at 9:28 PM
As I didn't had the time to find the ground wire (and didn't want to make a mistake...) I took my car to a Lebeau car center (Montreal) to get my remote programmed. The technician told me I couldn't program the remote because the LED is different (green on the old, red on the new -used- remote) .
It's weird because both have the same FCC ID: NAHRS5304 // CAN2686 1021 782 A. Do you know if it's true?
Posted By: tedmond
Date Posted: February 28, 2008 at 2:51 PM
i doubt it. a transmitter is a transmitter, it just programs to the brain and if the two sync then it should be good to go.
Posted By: phil@autostart
Date Posted: March 07, 2008 at 8:24 AM
True  the green LED on the transmitters indicated an SH system and the RED LED indicate an SR system.
if you look at the back of the main control unit you will be able to see the exact model of your system it will end with SH i.e.: AS-1584 SH
The exact part number for the transmitter you need is ASTR-214 CF (4 button, carbon fiber finish with green LED)
