05 toyota celica gt, remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102407
Printed Date: June 04, 2024 at 12:25 PM
Topic: 05 toyota celica gt, remote start wiring
Posted By: hammer16
Subject: 05 toyota celica gt, remote start wiring
Date Posted: February 21, 2008 at 1:42 PM
looking for wiring harness/diagrams to install remote start for 05 celica gt
Posted By: KarTuneMan
Date Posted: February 21, 2008 at 8:14 PM
12 VOLTS White Ignition switch harness   +
 The ignition switch wires change color through a connector on the steering column. Check both sides of the connector for these colors.
 IGNITION BLACK/ orange Ignition switch harness   +
 IGNITION 2 Blue/red Ignition switch harness   +
 ACCESSORY Gray
 STARTER BLACK/ white Ignition switch harness   +
 You may need to add a relay to isolate the starter and ignition wire during remote start since these wires are common when the ignition switch is off. See the TIP diagram.
 KEY SENSE Yellow pin-9 on 25-pin plug at Body ECU   -
 The Body ECU is located in the center console in front of the shifter, mounted to the junction block. Remove the plastic cover from the right side of the console to access, or remove the trim plate around the shifter.
 TACH SIGNAL See notes
 Remove the plastic cover on the engine to expose the 4 coils on the top rear of the engine block. Each coil has a BLACK/ white, blue / YELLOW and brown. Use the 4th wire at any of the coils for a tach reference. You can also use the BROWN / WHITE pin-27 on a 28-pin plug at the ECM located in the plastic case in front of the battery. This wire can also be found on the junction connector behind the plastic panel on the left side of the center console.
 LOCK PURPLE / white pin-15 on 22-pin plug at Body ECU   -
 UNLOCK Pink/black pin-16 on 22-pin plug at Body ECU   -
 DOORPIN RED / white pin-10 on 25-pin plug at Body ECU   -
 TRUNK PIN Lt.GREEN/ gray dots pin-22 on 22-pin plug at Body ECU   -
 BRAKESWITCH GREEN / WHITE At switch above brake pedal   +
 PARKLIGHTS Dk.green At parklight relay in right side of center console   +
 HAND BRAKE RED / black pin-19 on 22-pin plug at Body ECU   -
 HORN Blue/black pin-14 on 25-pin plug at Body ECU   -
 CLUTCH SWITCH BLACK/ white At switch on clutch pedal bracket   TYPE 2
