scytek trouble
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102459
Printed Date: May 23, 2024 at 11:54 AM
Topic: scytek trouble
Posted By: birdman1995
Subject: scytek trouble
Date Posted: February 22, 2008 at 9:15 PM
I have a astra 777 alarm and i cannot program remote it just goes into valet mode. I cycled the key on 4 time no luck I also tried 3 time no luck. I got a working galaxy 2000rs same problem. Someone please help.
Posted By: hydroz_23
Date Posted: February 22, 2008 at 9:30 PM
does it chirp when you turn the key back on the 4th time? are you trying
to program the lcd remote or the non paging remote? because programming is different.
turn key on/off, on/off, on/off, then on. it should chirp 4 times
press and hold the valet switch for 5 seconds. it should chirp 4 times and the led will come on.
press the lock button. it should chirp 1 time. then turn the key off.
Date Posted: February 22, 2008 at 9:42 PM
I am trying to program the lcd remote. After five seconds the led lights up and stays on even if I turn of my ignition.
Date Posted: February 22, 2008 at 9:48 PM
thank you for your response. I was trying to program it with out the siren hooked up and I guess I was doing it to fast. I hook up my siren and did it slow and it worked.
Posted By: audioman2007
Date Posted: February 23, 2008 at 9:51 AM
Arent all scytek's alarms program the exact same way? Meaning turning the ignition on/off same number of times and so forth?
Date Posted: February 24, 2008 at 4:01 PM
Does the lcd remote 2 way have to set up a ceryain way? I dont get 2 way. Not even when I hold "C" till con shows the release.
