remote start alarm on a manual
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103356
Printed Date: May 12, 2024 at 6:55 AM
Topic: remote start alarm on a manual
Posted By: compmania
Subject: remote start alarm on a manual
Date Posted: March 24, 2008 at 11:59 AM
I have an 02 Civic 5-speed and I just purchased an Audiovox Prestige alarm/remote start package.
In the manual for the alarm, it states that to install the alarm you MUST HAVE a automatic trans, a tach connection, and one other thing to do the install.
However, I purchased the unit to only use the alarm and its features. Can I hook the guy up without hooking the ignition connections and just forget about using the remote start feature? I really don't need/want to use it.
If I can do this, what exactly do I need to not connect with the unit besides the ignition connections? I believe its the APS997 model.
Posted By: usabuilt
Date Posted: March 24, 2008 at 12:42 PM
Just hook up the 12 volt constant, ignition 1, starter kill, door ,hood and trunk pin wires and connect the shock sensor.
