562t remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103613
Printed Date: May 13, 2024 at 11:56 PM
Topic: 562t remote start
Posted By: hayes48
Subject: 562t remote start
Date Posted: April 01, 2008 at 8:46 PM
If i only have one ignition in my car, i dont need to use ig2 right? and if i dont use ignition 2 do i need to use the red and white 12v connection? and if i use the red and white 12v and do not have ig2 hooked up will it cause a problem?
Posted By: chriswallace187
Date Posted: April 02, 2008 at 10:50 AM
It would help if you posted year/make/model...but as a general principle when doing a remote start you should think about what wires need to be poweRED / grounded on the car, not what wires from the remote start need to be connected.
If you have a 2nd acc. on your car use the pink/white ig2 for that and program it to run as 2nd acc. instead of 2nd ign.
If you don't have 2nd acc., tape the wire off and forget about it.
------------- C Renner's Auto Electronix
Posted By: howie ll
Date Posted: April 02, 2008 at 4:07 PM
Chris, your inbox is full! Howard
