audiovox remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103805
Printed Date: May 19, 2024 at 4:44 AM
Topic: audiovox remote start
Posted By: 2003kawasaki
Subject: audiovox remote start
Date Posted: April 07, 2008 at 7:59 PM
Im installing a Audiovox XRO9100, The instructions ask to connect the Geen wire to IGN2. As per wire any wire chart for a 2005 nissan altima there is no IGN2 to hook up. Can I use this wire on the second starter wire?
Posted By: Velocity Motors
Date Posted: April 07, 2008 at 8:38 PM
No you can not. The 2nd IGN is designed to have (+) output throughout the remote start sequence. If the unit doesn't have a designated 2nd starter wire, then you will need to install a relay.
------------- Jeff
Date Posted: April 07, 2008 at 10:26 PM
Thanks for the input, How do I set up a relay in my installation?
Posted By: spookiestylez
Date Posted: April 08, 2008 at 12:04 AM
you should have a extra wire harness for your remote start that has a (-) starter wire output. On the relay connect terminals 86 and 87 to fused 12v (ign harness) 85 will be your (-) starter output from the brain, and 30 will go to your 2nd starter wire
------------- RTFM
Posted By: Mike M2
Date Posted: April 08, 2008 at 6:30 AM
You can use the green output for the 1st accessory and the purple for 2nd accessory if you want everything in the car to turn on....
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: April 08, 2008 at 7:48 AM
I found a wire that is grounded while the starter output the remote start unit is active. I set this wire to a relay Thanks
Date Posted: April 09, 2008 at 7:06 PM
Mike M2 Do I need to change any of the programing for the green wire(IGN2) to work as the accessory? Kurt
