08 nissan altima alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104199
Printed Date: October 31, 2024 at 6:18 PM
Topic: 08 nissan altima alarm
Posted By: desh187
Subject: 08 nissan altima alarm
Date Posted: April 22, 2008 at 9:00 PM
Has anyone installed a factory keyless upgrade alarm on a 2008 Nissan Altima ?I need to install omegas ultimate system. This vehicle has a smart key system with push button start.
Any info will be very much appreciated.
Posted By: dtk1
Date Posted: April 22, 2008 at 9:47 PM
this cars are fun to do plenty of wires to run is a little time consuming keep an eyed for any lights on the dash this cars have been known for a faulty tire air pressure sensor. had a costumer came in with the light and he was acting like we made that light go off anyways what ever you do read the instructions this cars are a little bit different
Posted By: hurleyloser
Date Posted: April 23, 2008 at 1:17 AM
it's a very easy car actually, most of your wires are at the bcm behind the gauge cluster, just make sure to take your time and properly test all your wires.
Posted By: b-roy
Date Posted: May 01, 2008 at 5:22 PM
These cars are actually pretty easy when you take the time and do proper testing. If using an idatalink module, the guide comes with complete wiring info, down to the pin number for every wire.
