issue with 3 hornet 564ts
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105065
Printed Date: May 15, 2024 at 7:16 AM
Topic: issue with 3 hornet 564ts
Posted By: meltingplastic
Subject: issue with 3 hornet 564ts
Date Posted: May 27, 2008 at 10:57 PM
Around christmas time i installed 3 Hornet 564Ts into a friends family member's cars. I also installed a Python 791xv equivalent into his own personal car(and another friend installed the same unit into his brothers car) Both python units are working fine for the past 6 months but all 3 hornet installs are having issues with the remote/antenna The units are not responding to any of the remotes unless the remotes are placed up against the windshield by the antenna(both the lcd and nonlcd) Normally i would just chock it up to a bad antenna but all 3?? that doesn't make any sense to me. I know its not my install as this is the first time i've ever had an issue like this and the fact that its on 3 different vehicles. Do these units have a common problem of the antenna /wire/remotes going bad or maybe DEI just put out a bad batch and i got 3 of them. Any insight would be great!
-Mike
------------- Driving a Bagged, Caddied 02 s10
Posted By: dtk1
Date Posted: May 27, 2008 at 11:18 PM
those 564t personally i love it i have one on one of my personal cars the range sucks sometime it all depends where am at have you tried turning of the code hopping ? however I do agree with you three in a row sounds like it might be a bad batch how you also tried unplug in the antenna and plug in it back in ?
Posted By: chriswallace187
Date Posted: May 29, 2008 at 11:34 AM
Have you replaced the batteries in the Hornet remotes yet? 2-way remotes suck the juice out of them in no time.
------------- C Renner's Auto Electronix
Date Posted: June 04, 2008 at 5:15 PM
yes replaced the batteries... im gonna be swapping hte antenna and remotes next week and see what happens
Posted By: fcss
Date Posted: July 03, 2008 at 1:40 PM
how did that turn out I installed one in my wifes jeep and It doing the same thing its a avitel 4400 same as the 564t the remotes would stop working, I would re-learn they would work for a few days then I swaped out the remote same thing would happen, so I sent the brain and both remotes to d.e.i they sent me a whole new unit brand new saying there was something wrong with the one i sent them. I put it in the other day just plunging the brain to to my install it worked fine for a few days then the remote stop working for like 2 days then started working again it works when it wants the alarm has always worked fine she would disarm using the valet buttom, and I just saw this post Im going to swap out the antenna and wire from the new one d.e.i sent me, I was just wording how that went before i do this
