rs1000 test mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105404
Printed Date: May 21, 2024 at 4:11 PM
Topic: rs1000 test mode
Posted By: asjeep
Subject: rs1000 test mode
Date Posted: June 11, 2008 at 12:42 PM
Hello,
Installed an rs-1000 system and following the instruction manual it states to enter test mode "turn the key off and on 3 times and leave in the off position, then press the valet button 11 times, holding it down on the 11th until you hear 5 beeps"
When i do this i gut nothing but a driver page, it never goes into test mode to ease the install of the shock sensor (or the microwave I will be adding shortly)
Anyone gotten theirs into test mode?
------------- 2001 jeep wrangler se
Posted By: bdl666
Date Posted: June 12, 2008 at 10:47 PM
After you do press the valet switch 11 times and hold, you have to press the unlock and start buttons at the same time twice to get to zones 1 and 4 test mode.
------------- ieSpell rocks.
Posted By: mach1 03
Date Posted: June 14, 2008 at 9:57 PM
i am looking at getting the rs-100 what do you guy think of it and were can i get the dual radar sensor (rs-325) and the AC-78 Power Window Roll up & Down Module. also i have a 03 mustang mach 1 do i need the AP DATA LINK and i have heard that if you get it you don't have to do the indivedual conections for any oem fuctions is this true? thanks.
Posted By: asjeep
Date Posted: July 23, 2008 at 3:50 PM
I never did make it into test mode just did it the old fashioned way....
but now i find myself wanting to enable features and can't get into programming....
My best guess is that As this is going into a manual car I did not connect all the wires so remote start would not work (it's too dangerous)
so I am guessing one of those wires i did not use tells the alarm that i have turned the key on and off 3 times..... any idea which one it might be?
Posted By: asjeep
Date Posted: July 23, 2008 at 6:26 PM
never mind found my problem had the wrong keyed ignition source
