01 Civic LX Keyless and alarm Help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10564
Printed Date: March 23, 2026 at 7:00 AM
Topic: 01 Civic LX Keyless and alarm Help
Posted By: Obsidian
Subject: 01 Civic LX Keyless and alarm Help
Date Posted: March 07, 2003 at 5:41 PM
I want to put in an autopage alarm keyless entry system myself.  I've found a lot of wire diagrams but some good instructions and pictures would be nice.  Can anyone help.  I've done a lot searching and haven't found any diy.
Posted By: jrilla
Date Posted: March 07, 2003 at 6:56 PM
You are not going to find much anywhere as far as detailed instructions or pictures anywhere. I mean I have typed out a couple of pages before for someone when I just wanted to kill time, but that didn;t even help him. You really need to just sit down at a table with all of your tools and your alarm, and your vehicles wire diagram and prep the wire harnesses by cutting the wires you wont use shorter and taping the ends off, and grouping wires with cable ties that go to similar locations etc. Just think this thing through out in your head and then if you cant figure something out, post the specific question here. Solder your connections and tape them up really good. Dont touch 12v constant wires to metal and get something soft to kneel on. posted_image
J Rilla
Owner/Installer
Posted By: AutoObsessions
Date Posted: March 07, 2003 at 7:49 PM
12volts white   +   ignition harness
Starter BLACK/ white   +   ignition harness
Ignition BLACK / YELLOW   +   ignition harness
Power Lock WHITE/ blue   -   gray plug above driver kick panel
Power Unlock WHITE/ green   -   gray plug above driver kick Panel
Lock Motor yellow/black   5wi back of the fusebox
Notes: In the top left plug.
Unlock Motor YELLOW /GREEN   5wi back of the fusebox
Disarm Defeat yellow   5wi back of the fusebox
Parking Lights+ RED / black   +   back of the fusebox
Parking Lights- blue   -   factory alarm plug
Notes: The factory alarm plug is a green plug above the drivers kick panel.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger     -   factory alarm plug
Notes: The drivers door trigger is green, front passenger door trigger is lt. GREEN/ red, and the rear door trigger is GREEN / WHITE.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red   -   factory alarm plug
Horn Trigger orange   -   steering column
Here is the wire information. If I were yu I would have a professional install the alarm in this vehicle. The door trigger wiring is kinda complicated if you are a novice. If you look there are three different trigger wires for each door. They all have to be diode isolated from each other. But besides that everything else is pretty simple. Prepare you wire harness in advance with electrical tape. Route your constant, ignition and starter kill wires toward the ignition harness. Route your lock wires, door trigger wires, trunk trigger wires toward the driver kick panel. Mount your led and your valet in a nice location. Make sure you make quality connections that is the key for a trouble free installation. Any other questions just e-mail me at crhbxny@msn.com
Posted By: Obsidian
Date Posted: March 08, 2003 at 4:14 PM
the ignition harness is way wrapped up.  Is there another 12volt constant I can grabbe?  Is there one int he green alarm harness?  I'm not doing the alarm..just keyless entry
Posted By: jrilla
Date Posted: March 08, 2003 at 11:28 PM
the battery always worksposted_image
J Rilla
Owner/Installer
