clifford g4 remote problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=106108
Printed Date: June 11, 2024 at 12:45 PM
Topic: clifford g4 remote problem
Posted By: louisjames
Subject: clifford g4 remote problem
Date Posted: July 13, 2008 at 10:22 PM
hello there, searched hi and low for a fix but cant find one, ok i have a concept 600 in my car, i only had the 4 button carbon remote which works fine, i purchased a 5 button (one on the side) master remote and am trying to add it. the problem is with the remote, after putting in new battery ,which ever button i press the light on the fob just flashes, where as it should stay lit whilst holding any button. if i hold side button then another it flashes faster, i had this once before with another master and just randomly pressed them all and it started working correctly. problem is whilst its like this the alarm cant see it when in adding mode. does any one know what i can do or is there a sequence i need to do with the remote?? this is really frustrating, any help GLADLY appriciated. thanks
Posted By: OmarR
Date Posted: July 14, 2008 at 12:56 PM
The light is NOT supposed to stay solid while you hold down a button. It is supposed to flash. When you hit the shift key, and than one of the 4 face buttons, the light now flashes twice as fast, indicating that you are now up one level on channels 5-8. When you hit the shift key TWICE, and then one of the 4 face buttons, the light now flashes 3 times as fast, indicating that you are now up two levels on channels 9-12. When you hit the shift key 3 times, and then one of the face buttons, the light now flashes 4 times as fast, indicating that you are now up 3 levels on channels 13-16. If you cannot reach the last level, then you have purchased a G3 remote and you need a G4 remote. Check the ID number to see if this is the case.
Date Posted: July 14, 2008 at 1:17 PM
OmarR] wrote:
p>The light is NOT supposed to stay solid while you hold down a button. It is supposed to flash.When you hit the shift key, and than one of the 4 face buttons, the light now flashes twice as fast, indicating that you are now up one level on channels 5-8. When you hit the shift key TWICE, and then one of the 4 face buttons, the light now flashes 3 times as fast, indicating that you are now up two levels on channels 9-12. When you hit the shift key 3 times, and then one of the face buttons, the light now flashes 4 times as fast, indicating that you are now up 3 levels on channels 13-16. If you cannot reach the last level, then you have purchased a G3 remote and you need a G4 remote. Check the ID number to see if this is the case.
oh cool, ok the number on back is 64-376 and above says mpt1340 licence exmpt, does that mean anything to you?
Posted By: howie ll
Date Posted: July 14, 2008 at 2:30 PM
Yes it's a UK spec remote from a G2 or 3 and IS NOT compatible with a G4 alarm. That apart Omar is correct.
Date Posted: July 14, 2008 at 2:32 PM
ok mate, thanks for the info. very helpfull.
