2008 tacoma remote start wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=108306
Printed Date: June 08, 2024 at 12:11 AM
Topic: 2008 tacoma remote start wiring
Posted By: nothing13
Subject: 2008 tacoma remote start wiring
Date Posted: October 21, 2008 at 1:15 PM
Hello,
Since the only shop in town i trust won't do a remote start on a manual transmission (They only sell DEI) i've decided to give it a run myself. I have done one remote start on an old Mercury Topaz that couldn't have been more straight-forward, so i thought i'd try my 2008 Tacoma X-Runner. I have decided to go with either a Compustar Pro 2WSSR or a Pro 2W9000FMR unit. I think they are the same brain (CM5000) that accept the new Blade override module.
I have been researching a lot on this forum and others and I think i have the wiring figured out, just wanted to post a list with the hopes one of the experts would be so kind to point out any errors before i start tearing into my truck.
Alarm Connector 1:
Red (12v constant) to vehicle WHITE/ Blue (12v constant)
RED / White (12v constant) to vehicle WHITE/ Red (12v constant)
Violet (- when armed) prewired to Starter Kill Relay
Green and Red (Ignition) to vehicle Blue / YELLOW (Ignition 1)and prewired to starter kill relay
GREEN / WHITE (Park Lights +) to vehicle Green at fusebox
White (Accessory) to vehicle WHITE/ Green (Accessory)
Yellow / YELLOW Black (Starter kill relay) to vehicle BLACK/ White (Cut starter 1)
Black to factory ground in drivers kickpanel
2nd Ignition Relay
Pins 86/87 to Red (12v constant) from Connector 1
Pin 85 to Green - ignition 250 mA output on Connector 3
Pin 30 to vehicle BLACK/ Red (Ignition 2) at vehicle ignition harness
2nd Starter Relay (Prewired to Connector 1)
Pins 86/87 prewired to RED / White (12v constant) from Connector 1
Pin 85 to RED / Black - starter 250 mAoutput on Connector 3
Pin 30 to vehicle GREEN/ Black (Starter 2) at vehicle ignition harness
Alarm Connector #3
Blue/Black (- lock) to vehicle Violet in kickpanel
Blue (- unlock) to vehicle GREEN/ Black in kickpanel
Yellow/Black (Tach) to vehicle BLACK/ White at Diagnostic Plug
RED / White (Door input) to vehicle GREEN / WHITE near fusebox
Lt.Blue/White (Brake) to vehicle Blue at brake pedal
Lt.Blue (hand brake) to vehicle GREEN/ YELLOW at fusebox
GREEN / WHITE (- parklights) to vehicle Green at switch harness
Violet (Dome light) to vehicle Black at fusebox
I will connect the Keysense and the other 2 wires as directed for the immobilizer bypass. They directions from Firstech are very detailed.
Do I need to connect the horn output from the remote start module to my vehicle if i would rather the siren to all the chirping? (arm, disarm, etc..)
Any one with experience with both Compustar models? is the new Pro2WSSR worth they extra cost?
I think that should just about do it. Thank you very much in advance to anybody willing to take a few minutes to confirm my list.
Cheers,
Chris
Date Posted: October 21, 2008 at 8:38 PM
i'm really looking to see if i am on the right track for the 2nd starter and 2nd ignition relays, and also wondering if i need to put diodes anywhere. (Door locks, etc..) Any feedback would be much appreciated.
Posted By: i am an idiot
Date Posted: October 21, 2008 at 8:53 PM
On your second ignition and second starter relays, are the wires you intend to connect to terminal 85 a ground output?
Date Posted: October 21, 2008 at 9:12 PM
They are all listed as negative outputs, is that what i am looking for?
Date Posted: October 21, 2008 at 9:25 PM
Yes all seems well there.
Date Posted: October 21, 2008 at 10:50 PM
Do I need diodes on the door lock/unlock wires?
Posted By: jmw505
Date Posted: October 21, 2008 at 11:08 PM
when testing the DOOR LOCK and UNLOCK wires, you must TEST these wires when turning the kEY in the DRIVERS DOOR KEY CYLINDER ONLY
POWER UNLOCK GREEN/ BLACK (TYPE B)(Requires Double Pulse)iN DRIVERS KICK PANEL, 10-Pin plug, Pin 8
LOCK MOTOR WIRE BLUE/RED (+)IN DRIVERS KICK PANEL, 12-PIN Plug, Pin 10
there is no need for diodes
Date Posted: October 22, 2008 at 1:21 AM
Thank you very much for your help guys. :)
Date Posted: November 09, 2008 at 9:21 PM
Alright... Did the installt today. Went pretty smooth except for a couple things i am having trouble with. First, I didn't even think about a clutch bypass. Anyone know where i should be looking to tie into for that? The install manual doesn't really say much. Secondly I am using the Blade module for the immobilizer bypass. It says after hooking it up all you do for programming is insert the key and wait for the green light. I am getting nothing. I dont even get a red light to signal that its improperly programmed like the manual states. The place i ordered it from said he was going to download the firmware to the module for me, and i received the brain with the blade module installed in it, so i assume he did. Long story short with the key in the ignition and my foot on the clutch it works great. Just need a little help to figure out the last few things...
Posted By: jmw505
Date Posted: November 09, 2008 at 11:26 PM
i personaly never can get them to program i alwas use the by pass the requires a key to be in a box under the dash
Date Posted: November 10, 2008 at 3:28 PM
Ahhh!
For some reason the siren and horn aren't chirping when they should now... its not in silent mode...? It was working fine yesterday. Not to mention when trying to put it into reservation mode the car just shuts off now.
The only thing i did change today was the keysense jumper in the brain. I had the keysense hooked up for the Blade module, and not for the brain (maybe i need diodes..?). When i hooked it up to the brain the siren starting working yesterday. I noticed the default was a positive input for glow plugs for that wire, so i adjusted the jumper accordingly. Now the siren doesn't work, even when i switched it back... Do i need the keysense hooked up for both the brain and the blade module?
And i still haven't tackled the clutch bypass.
I'm confused! Help please!
Posted By: jmw505
Date Posted: November 10, 2008 at 9:55 PM
if you arm it and set off the sensor does it still kick the siren
Date Posted: November 11, 2008 at 2:14 AM
It gets the remote buzzing away when i insert the key when armed, but no siren. When i shake the sensor it shows up on the remote too.
It really seems like its stuck in valet mode, but i cant seem to get it out, nor does it show up on the remote. Cycling the key on/off 5 times in the ignition does nothing... and the secure valet switch isn't working either.
Date Posted: November 11, 2008 at 12:23 PM
Hmm.. Well, today cycling the ignition seems to work.. i re-leaned the tach signal to see if that was it.. still nothing. Lock/Unlock works, other than that its a paper weight.
Posted By: jmw505
Date Posted: November 12, 2008 at 12:57 AM
i would try pulling off the keysense wire and see if you get the horn and siren back
Date Posted: November 12, 2008 at 1:50 AM
I tried that, pulling the cm5000 key sense and the blade harness one, with no luck either way. Its gonna sit for the night with the battery disconnected and try again in the morning. Maybe i'm getting a bad tach signal from the ODB connector..? I measured over 6 volts with little change when the engine reved at higher RPM... Seems weird that it worked for a bit though. Would that cause any of these issues? Maybe disable the unit except for the door locks until a good tach signal is obtained?
Date Posted: November 12, 2008 at 1:16 PM
Alright.. I got all the functions working again.. Still can't get the bypass to program (just checked the wiring, all A-OK) and have to tackle the clutch bypass.
Date Posted: November 12, 2008 at 2:38 PM
Hahaha... I'm such a pet monkey!
The whole time i had the 20-pin connector for the Bypass plugged in backwards! Apparently, it will fit even without those tiny little channels lined up... Amazing what better lighting does..
Wow.. I can't believe i wasted all that time for something so stupid!
Posted By: jmw505
Date Posted: November 12, 2008 at 8:35 PM
lol thats funney
Date Posted: November 14, 2008 at 1:57 AM
Anybody care to lend a hand with the clutch bypass for this "manual transmission safe" install? :)
