clutch bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109565
Printed Date: May 14, 2024 at 2:38 AM
Topic: clutch bypass
Posted By: traviscoots
Subject: clutch bypass
Date Posted: December 07, 2008 at 9:31 PM
I believe i have a type3 clutch wiring system, not exactly sure what that is, explanation on the different types would be super.
anyways, i own a 2005 dodge dakota 6 speed, and what im aiming to do is install a switch that will bypass the clutch so i can start the truck without the clutch pushed in. much like the toyota trucks had in the 90's
i am deciding on whether or not to make it to where i have to push it each time which i would believe i could just use a momentary switch, or make it to where i can install a switch that shows the clutch is in at all times unless i wanna turn it off.
THIS IS STRICTLY JUST FOR CUSTOMIZING PURPOSES AND PRACTICE ONLY.
that and i want to install a remote start and if the switch is not pushed i will be hooking up a safety to where it does not engage.
any help is appreciated thanks.
possibilities are limitless. if you can think it you can do it.
Posted By: KarTuneMan
Date Posted: December 13, 2008 at 10:01 PM
If you get a remote start that is designed for a manual trans I'll tell ya how to bypass the clutch.
You have NOT givin enough info, and come REAL close to busting the forum rules on this issue?
THIS IS STRICTLY JUST FOR CUSTOMIZING PURPOSES AND PRACTICE ONLY.     This doesn't matter.
Posted By: tedmond
Date Posted: December 14, 2008 at 5:58 AM
agreed. grab a manual safe starter or automatic starter with DEI vss.
Date Posted: December 17, 2008 at 11:45 PM
hmm. guess i wasnt aware of the rules of the forum. but the only information i was really needing is what does type 3 clutch mean? i know type a is pos. type b is neg. and type c is rev. for door locks, but not sure on clutchs. dont exactly know what other info to give other than that. i stated what i wanted to do, i just need to know how to replicate the clutch switch.
if i installed a manual trans r/s the manual will tell me how, but thats not what im aiming for because the sequence you have to go through is dumb. justs want to push a button to cancel my clutch and make it to where the r/s ONLY works when this button is pushed.
the statement about strictly customizing was only made so no one thinks im trying to make something work on a customers vehicle, im not ghetto.
i hate any dei product, ultrastart and fortin are way better, they actually work and if you dont think dei sucks, why are they discontinuing their bypasses? they are buying from fortin now.
anyways, thanks.
Date Posted: December 18, 2008 at 2:05 AM
They gots to do somethin to get their stock above .25 a share.
