06 murano runs rough
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109903
Printed Date: May 09, 2024 at 4:23 PM
Topic: 06 murano runs rough
Posted By: prdjr165
Subject: 06 murano runs rough
Date Posted: December 20, 2008 at 12:06 PM
06 murano runs rough after installation of scytek 2000 remote start and cansl2 bypass module.It runs rough then dies when remote started and with the key!!!
Posted By: kassdog
Date Posted: December 20, 2008 at 2:52 PM
A couple things, make sure you have the right tach is hooked up good and that you didn't ground it. Have seen that happen before.
Posted By: KPierson
Date Posted: December 20, 2008 at 4:19 PM
Is the car throwing any codes? Does it start right up or does it take a while to actually start running?
------------- Kevin Pierson
Posted By: prdjr165
Date Posted: December 20, 2008 at 4:33 PM
the tach is connected to the can-sl2 module,but it never was programed through the remote start because it won't run long enough.The murano starts right up everytime but sputters and dies within a few seconds.
Posted By: KPierson
Date Posted: December 20, 2008 at 4:45 PM
Are there any codes?
Posted By: prdjr165
Date Posted: December 20, 2008 at 4:57 PM
I found the problem,It turns out that the air intake hose was loose.I pushed the hose on the airhorn and tightened the clamp and all is well.Thanks for the help!!!It never threw any codes...
Posted By: Hornshockey
Date Posted: December 21, 2008 at 9:54 AM
That has happened to one of the guys at my shop, but his didn't happen for 3-4 days after the RS install. So we ended up paying an $80 dealer bill and learning a lesson. Apparently those Muranos are very sensitive when it comes to that intake. The one we had problems with wasn't totally disconnected, the guy said he looked at it and didn't see anything wrong with it, but according to the dealer, it was loose.
------------- Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
