Starter turns but car doesnt start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11000
Printed Date: June 08, 2024 at 7:35 AM
Topic: Starter turns but car doesnt start
Posted By: nadeemr
Subject: Starter turns but car doesnt start
Date Posted: March 16, 2003 at 8:08 PM
I installed an Audiovox remote starter in my 93 Toyota Camry XLE (6 Cyl). I programmed the tech and the unit confirmed that it learned the tech. The problem is that when I try to start using remote starter, the starter tries to start the car but it does not start. Does anyone knows if I there is any factory module that I need to bypass? Everything else like door lock/unlock, interior light supervision and parking lights work fine.
Posted By: Scott35
Date Posted: March 16, 2003 at 8:16 PM
Could you maybe have ignition 1 and 2 switched?
------------- Tacomacrew
Posted By: Scott35
Date Posted: March 16, 2003 at 8:21 PM
Ignition 1 is BLACK/ orange, ignition 2 is BLACK / YELLOW.
Posted By: nadeemr
Date Posted: March 17, 2003 at 4:30 PM
I found the problem last night after I post the initial message. The remote starter's factory default setting was 'IGNITION 2 OFF DURING CRANK' . When I changed it to ignition 2 on during crank, it worked. By the way does it matter if I accidently switched the ignition 1 and 2 wires? since both wires were of the same guage and my assumption is that in my car both turn on at the same time. Also if anyone knows about what Ignition 2 wire does in 93 camry? Does Ignition two relay have to come on to start the car? I am asking these questions because I still think that I may have switched the two wires.
Posted By: Scott35
Date Posted: March 17, 2003 at 4:45 PM
On my Tacoma, it would not crank when the wires were switched.
Posted By: tom cat
Date Posted: March 17, 2003 at 4:46 PM
it will not matter as long if you have power on them when is starting
