2008 g35x 12 volts + at the bcm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110534
Printed Date: May 09, 2024 at 4:55 PM
Topic: 2008 g35x 12 volts + at the bcm?
Posted By: peterubers
Subject: 2008 g35x 12 volts + at the bcm?
Date Posted: January 10, 2009 at 9:05 PM
Looking to install a auto doorlock module (KP's) in this vehicle, need to know where to access 12 volts+ at the BCM or very near the BCM. Thanks in advance. ------------- The search function is your friend.
Posted By: i am an idiot
Date Posted: January 10, 2009 at 9:24 PM
Is the battery not an option? Why take a chance on accidentally tagging a 12volt output wire of the BCM that may be limited in current, and taking out the BCM.
Posted By: myinstallguy
Date Posted: January 10, 2009 at 9:26 PM
Found a very raw schematic. Please test & do not quote me on this. Connector M118 pin 1 and Connector M119 pin 11. Sorry, no colors. I'll research it more, till then good luck. ------------- *Installer since '89*
Date Posted: January 10, 2009 at 10:20 PM
It makes sense to tag a definite 12 volt source like the battery/12volts at the ignition harness - make sense that I wouldn't want to rob the BCM of current. MrInstall -- lemme know what ya find, thanx for your help guys ------------- The search function is your friend.
Posted By: Chris Luongo
Date Posted: January 11, 2009 at 7:39 AM
What kind of automatic doorlock module? I've seen a handmade module for sale online (KPierson I think?) that locks the doors when you drop the car into gear, or when you speed up. Is that it?
That should take almost no current at all.
Anyway, at the BCM in the kick panel, there are several plugs with dozens of small wires in them.
There's another plug, however, with only three pins. Two medium size wires, and one larger one......WHITE/ black I believe.
I use that heavy wire for my power source for remote start in all my Nissan/Infiniti remote starters. The remote starter for that car probably draws a good 1-2 amps. If that doesn't hurt anything, I'm sure your doorlock module will be fine.
Obviously, if the module you're installing doesn't have its own fuse on the harness, you should add an inline fuse, very close to where you tap for power.
That way, if your wire shorts out to something, your fuse will blow and your module will of course stop working, but the car will continue to run.
Date Posted: January 11, 2009 at 9:58 AM
Hey Chris, Thanks for your help -- yeah, it's KP's doorlock module. His unit comes with an inline fuse -- so no worries on that. Thanks for your help, I'll look for that wire you mentioned and use my DMM to confirm ------------- The search function is your friend.
