2006 gmc serria battery light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=110694
Printed Date: May 29, 2024 at 2:37 AM
Topic: 2006 gmc serria battery light
Posted By: monty_77
Subject: 2006 gmc serria battery light
Date Posted: January 15, 2009 at 7:12 PM
I installed a remote start in a 2006 GMC Sierra and it starts and runs just fine everything including the door locks seem to work. On the other hand, the Battery indicator stays on when remote started. It does go out when the key is turned on. Is this a problem or should u just ignore it.
Posted By: myinstallguy
Date Posted: January 15, 2009 at 8:35 PM
I do not have an answer (yet) but, does the Batt light turn off when the key "turns on" or after you press the brake (shutting down the RMST) with the key already in the on position. Do not know if it's relevant, which bypass did you use? ------------- *Installer since '89*
Posted By: monty_77
Date Posted: January 15, 2009 at 9:02 PM
The bypass is Xpresskit GMDLBP.
when you turn on the key
Posted By: Mike M2
Date Posted: January 15, 2009 at 9:18 PM
Did you connect both the white and the pink ignition wires?
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: monty_77
Date Posted: January 15, 2009 at 9:52 PM
Yes i did connect both of them and the two accessory wires. The pink is connect through the main harness ignition and the other is on programmable relay set to ignition. would it still start if one of them had a blown fuse.
Posted By: chadwa2003
Date Posted: January 16, 2009 at 8:48 AM
Where did you get your 12 volt connection from?
Posted By: monty_77
Date Posted: January 16, 2009 at 10:34 AM
From the two red wires at the ignition harness same place as the pink ignition and the yellow starter wire come from.
Posted By: Mike M2
Date Posted: January 16, 2009 at 3:20 PM
Check for 12volts on both igntion wires and both accessory wires when it is remote started. It has to be lacking one...
Tech Manager
CS Dealer Services
Posted By: monty_77
Date Posted: January 16, 2009 at 7:10 PM
ok thanks i will take a look at it
Posted By: Velocity Motors
Date Posted: January 16, 2009 at 9:41 PM
While your at it, meter the IGN & the ACC wires for proper timing. I have the same problem with a 2002 Chevy and the BATTERY LIGHT and the ABS light turn on, but only with remote start.
------------- Jeff
Posted By: realsnake
Date Posted: January 16, 2009 at 10:40 PM
cluster's on the bus, gm network is overloaded with to many nodes. I had that before, idata have a backdoor: orange black wire at ground slow down data rate, and change something on the network the patch work on the other moudule you have to cut off ignition input to turn them off. maybe nothing related but my 2 cents.
