toyota venza, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111310
Printed Date: May 17, 2024 at 4:55 AM
Topic: toyota venza, remote start
Posted By: mike1080
Subject: toyota venza, remote start
Date Posted: February 04, 2009 at 10:00 AM
i have done alot of toyota push buttons over the last 2 years, but the venza is different. i have always used the fortin keyoverride sl-2 or keyoverride-all and never had an issue. now with the venza, fortin is saying you have to lose one of the remote keys. has anyone done a push button venza without losing a key? as far as i know, i-datalink and dei don't make anything. anyone who may have done one and can help it would be appreciated.
Posted By: Chris Luongo
Date Posted: February 04, 2009 at 11:14 AM
Toyota has changed the way their immobilizer encryption works on most 2009 models, depending on production date.
I thought nobody had figured out their new system yet, but Fortn's site says that the Venza is now supported:
https://ifar.ca/en/vehicles/toyota/venza/2009/
By the way, I used to use the key-override-sl2, but give the key-override-all a try on your next pushbutton Toyota. Faster install, no relays required, instructions come with the package, and it only costs a little bit more.
I would call Fortin a second time and verify that the key-override-all really works on the Venza now, and ask for sure if you need to lose a key or not.
Posted By: BNLUIS
Date Posted: February 04, 2009 at 1:23 PM
it works you need to flash it the key overide-all to a different software. You will defentlly loose a key wich is one of the remotes it self. Here is the manual for the 2009 Venza. https://ifar.ca/en/download/904/key-override-all_toyota_venza_%282009%29.rev-a.pdf ------------- Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Posted By: robertsc
Date Posted: February 04, 2009 at 4:41 PM
thanks for pointing that out and only 2 diodes as well that will be a time saver
Date Posted: February 04, 2009 at 9:46 PM
Ah, thank you bnluis, that's what I was looking for.
That's good to know.....so they still don't have the immobilizer figured out yet, then.
For the Venza, the key-override-all is just to help out with controlling some of the circuits in the car, and to allow take-over without having to shut down the car first.
Posted By: ricardoboston
Date Posted: September 10, 2009 at 5:24 PM
i need an idea about a 2009 toyota venza please. i need to know if the 2009 venza regular key . its not smart key its not push button start .works with bypass transporder 556uw ,i will give up one key not problem thanks
Posted By: Mike M2
Date Posted: September 11, 2009 at 6:49 AM
You can use a 556UW in any key Toyota. It works fine...
------------- Mike M2
Tech Manager
CS Dealer Services
