viper 5900 siren has stopped working
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112166
Printed Date: May 28, 2024 at 3:58 PM
Topic: viper 5900 siren has stopped working
Posted By: dew1989
Subject: viper 5900 siren has stopped working
Date Posted: March 07, 2009 at 12:19 AM
So I just finished installing my Viper 5900 into my integra and low and behold the siren has just stopped working all toghether. It did work fine, then all of a sudden nothing, no chirps, nothing when alarm is triggered. I was goofing around with the remote so maybe I screwed something up? And no I'm not in valet mode (led is not solid) ... any suggestions? Thanks
Posted By: howie ll
Date Posted: March 07, 2009 at 3:23 AM
Back to basics, check the brown siren wire at the alarm CPU, it should go 12v+ when you arm the vehicle or trigger the alarm. Check the continuity from this to the siren's red wire and make sure the sirens's black wire has a good ground. Check the siren itself by keeping the black lead grounded and flash the red to battery. If none of this shows up the unit's siren output has blown.
