remote start, auto headlights stay on
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112176
Printed Date: May 31, 2024 at 6:37 PM
Topic: remote start, auto headlights stay on
Posted By: 1badtundra
Subject: remote start, auto headlights stay on
Date Posted: March 07, 2009 at 12:26 PM
I installed a Viper 5901 on my 2008 Toyota Tundra and when I remote start the truck and remote start it off the headlights stay on if left on auto.
I need assistance on over coming this problem.
Posted By: Mike M2
Date Posted: March 07, 2009 at 4:19 PM
You need to pulse the drivers door trigger wire after the RS turns off. Your Viper may have a rearm factory alarm wire, you can use that. Another way to go is to add a relay to interupt the auto light wire at the turn signal switch(which is the way i do it). You want to interupt this wire the entire time the RS is on.
------------- Mike M2
Tech Manager
CS Dealer Services
Date Posted: March 07, 2009 at 9:19 PM
Mike,
I figured it out phewww.
Posted By: abad355ta
Date Posted: July 07, 2009 at 5:29 PM
I tried to pulse the driver door after rs turns off, however it does it immediately after, and the truck doesnt recognize it. What is the other way you speak of sir?
thanks
TR
Posted By: profuse007
Date Posted: July 08, 2009 at 1:05 AM
trying doing it manually w/ a strong ground?
------------- Houston,TX
Posted By: Mike M2
Date Posted: July 08, 2009 at 6:57 AM
Go to the switch and find the wire that goes to ground when you turn the auto headlights on, interrupt that wire with a relay whenever the RS is on(using the statis wire).
Tech Manager
CS Dealer Services
Date Posted: July 08, 2009 at 9:28 AM
im n ot really sure how to interrupt with a relay, ill search. thanks brother
Posted By: t&t tech
Date Posted: July 08, 2009 at 4:14 PM
using a relay single pole double throw wire it like this, cut the wire you desire to be interrupted and wire like this pin 87a- side from switch pin 30 - other side of cut wire pin 86 - ignition pin 85- status output wire pin 87 remains unused ------------- COMMIT YOUR WAY TO JEHOVAH AND HE WILL ACT IN YOUR BEHALF.
PSALMS 37:5
Date Posted: July 08, 2009 at 7:33 PM
bow, bow,
your the man
TR
Posted By: t&t tech
Date Posted: July 08, 2009 at 7:41 PM
are you being sarcastic? ------------- COMMIT YOUR WAY TO JEHOVAH AND HE WILL ACT IN YOUR BEHALF.
PSALMS 37:5
Date Posted: July 08, 2009 at 8:10 PM
not at all, im bowing to you!
thank you!
