2007 chevy silverado alarm keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=112262
Printed Date: May 31, 2024 at 7:43 PM
Topic: 2007 chevy silverado alarm keyless
Posted By: start25
Subject: 2007 chevy silverado alarm keyless
Date Posted: March 11, 2009 at 2:30 AM
Hello.... I'm going to install Alarm and Keyless entry on 2007 Chevy Silverado and I was wondering if anybody done one of these before... Do I have to have interface module or can I make doorlocks work without it? Do you have to go in each door to connect door triggers or is there better option, also parking lights wire where do you find that other then under hood. Thank you all for your help....;)
Posted By: james bond 007
Date Posted: March 11, 2009 at 9:15 AM
you will need a bypass mod to bypass the transponder pk3 anti-theft in you truck anyways so you may as well get the next model up that will do the disarm and the locks at the same time that way you won't have to open the door panel to get the disarm wire, the parking light wire is at the BCM to the left of the steering rack the colour is light blue
Posted By: ajstetler
Date Posted: March 11, 2009 at 9:56 AM
Is the truck a 2007 Silverado Classic, or new body style? Classic is Passlock 2 and the new body style is PK3. Both trucks the door locks, front triggers, and disarm can be controlled via data (much easier).
------------- Big Al
Posted By: start25
Date Posted: March 11, 2009 at 5:07 PM
Got it done, didn't need any interface module for door locks or triggers. Found door locks @ BCM module bottom plug pink/black and ORANGE / black wires, and door triger wires come out of doors and you can find them in kick panels. Thanks for all of your help...
Posted By: Mike M2
Date Posted: March 11, 2009 at 5:09 PM
He does not mention a remote start, just alarm with keyless. No module is needed for this truck if it is a standard cab or an extended cab. You will find negative pulse locks in the fuse box, drivers end of dash. The crew cab does need one for locks as they are data controlled.
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: Mike M2
Date Posted: March 11, 2009 at 5:10 PM
Well you beat me to it!
Tech Manager
CS Dealer Services
