alarm autopage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113309
Printed Date: May 21, 2024 at 3:56 PM
Topic: alarm autopage
Posted By: shaggy_ky2001
Subject: alarm autopage
Date Posted: April 20, 2009 at 11:52 PM
i just installed a autopage rf 525 into a 05 dodge ram. things are working fine.. now the issue i am having is this alarm as most do have a hood trunk trigger.. well the switch is on the tailgate so if opened alarm will go off.. the wire running from the alarm is good. the pin is in a good spot for ground.. thing is when armed and open tailgate the allarm will not sound. this worked with the old alarm.. does anyone have any ideas on what i can do to make it work becides ordering a strip for the tailgate..
Posted By: tommy...
Date Posted: May 14, 2009 at 7:09 AM
which wire did you use on the alarm for rear door?
------------- M.E.C.P & First-Class
