2009 kia borrego bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113571
Printed Date: May 13, 2024 at 4:18 PM
Topic: 2009 kia borrego bypass
Posted By: brianh
Subject: 2009 kia borrego bypass
Date Posted: May 03, 2009 at 2:35 PM
I have a 2009 Kia Borrego and I have a Viper 5901 unit to put on it. I also have the Xpresskit DLPK for the vehicle. The Borrego is not listed in the manual. I called Directed electronics about this and they said to use diagram 10 for the Borrego. I just wanted to double check this with a actual installer before I get started. I guess the wire colors in the number 10 diagram should be right for this vehicle,as well as the location to find them? If anyone can help me It would be most appreciated. Thanks in advance. Brian
Posted By: Chris Luongo
Date Posted: May 03, 2009 at 4:20 PM
First, let me be honest and say I've never worked on a Borrego, and haven't even seen the wiring diagrams for it.
But, generally speaking, you're not going to find an easy immobilizer bypass for a Hyundai/Kia product.
I think ADS (idatalink.com) and Trilogix (bypasskit.com) might make something, but you can't program it by yourself. It needs to be programmed to the car using the dealer's scan tool. Unless you have a friend at the dealer, they'd probably charge you just as much as if you had an extra key made.
So anyway, whatever module you find, it's going to save you from running wires into the door to control the doorlocks.....well worth it in my opinion.
But you're still going to most likely end up with a spare key in a universal bypass box to take care of the immobilizer part.
Posted By: brianh
Date Posted: May 21, 2009 at 3:43 PM
I diagneed info on the door lock bypass unit. The express kit DLPK. I was told to use the # 10 diahgram(in the book that comes with it). There is two ways to hook up the high can and low can wires(data wires) There is a 1 way and a two way diahgram. If anyone has used this unit and could shed some light on it I would be more than thankful. Thanks in advance! Brian
