95 accord, starter disable, autopage rf-315
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=113948
Printed Date: June 11, 2024 at 6:50 PM
Topic: 95 accord, starter disable, autopage rf-315
Posted By: djkurious
Subject: 95 accord, starter disable, autopage rf-315
Date Posted: May 21, 2009 at 6:21 PM
Ok, I have installed a Autopage RF-315 alarm system into my car, partially. The problem I am having is the starter disable wiring. In the book of the alarm and on the relay , it states that red=12v+ignition which wire is this and where? yellow=starter wire (key side) which wire is this and where? purple=starter wire (motor side) which wire is this and where? white wire to alarm orange wire brain The only one I understand is the white wire that goes to the orange wire coming from the alarm Also, on the wiring diagram for my car, I noticed that the head lamp is blue and it is on the left of column blue connector. the book states it needs a relay. Do I wire this as I would any relay for a negative door trigger? Other than that, everything else is working flawlessly. See attachments for the wiring diagram of the alarm
Date Posted: May 21, 2009 at 6:26 PM
Posted By: t&t tech
Date Posted: May 21, 2009 at 6:33 PM
the starter wire would be located in the main ignition harness, you could trace from the back of the switch where you insert your key to start, the colour wire you're lookin for is BLACK/ white, cut it in half at a suitable point where both ends can be reconnected to the relay, yellow goes to the side coming from the keyswitch the purple to the other side, the red tap this feed on to the thick gauge BLACK / YELLOW wire frm the same harness. i don't understand your last question about the relay and the headlamp and the door trigger, please clarify. ------------- COMMIT YOUR WAY TO JEHOVAH AND HE WILL ACT IN YOUR BEHALF.
PSALMS 37:5
Date Posted: May 21, 2009 at 6:39 PM
[IMG]https://i130.photobucket.com/albums/p271/djkurious815/alarm1.jpg[/IMG]
Posted By: t&t tech
Date Posted: May 21, 2009 at 6:45 PM
LINK don't work
PSALMS 37:5
Date Posted: May 21, 2009 at 7:15 PM
Posted By: t&t tech
Date Posted: May 21, 2009 at 7:20 PM
i'm half blind man, (not literally). i can't make out squat.describe your wires and what they do.
PSALMS 37:5
Date Posted: May 21, 2009 at 7:40 PM
Thanks for your help! When you say "purple to the other side" which wire is that? Color? The other question I was asking was about the domelight. Is that referred to on the wiring harness from this site as the "headlamp?" If so, I see I have to wire a relay for that
Posted By: t&t tech
Date Posted: May 21, 2009 at 9:25 PM
purple to the other cut side of the starter wire, the side going towards the engine to the solenoid, the domelight i did one a while back, didn't use a relay though, picked up the door and trunk contacts behind the iinstrument cluster, diode isolate all four, bands facing away from alarm, also not too sure about your haedlamp statement, but use the parking lights or hazards. cheers
PSALMS 37:5
Posted By: t&t tech
Date Posted: May 21, 2009 at 9:26 PM
Constant 12V+ | White | Ignition Switch Harness or Fuse Panel | Starter | BLACK/ White | Ignition Switch Harness | Ignition | BLACK / YELLOW | Ignition Switch Harness | Accessory | Yellow | Ignition Switch Harness | Tach | Blue | Distributor | Brake Switch | GREEN / WHITE | Brake Switch | Trunk Pin | ORANGE / Silver (-) | Right of Column Gray Connector | Parking Lights | RED / Black | Fuse Panel Blue Connector | Head Lamp | Blue | Left of Column Blue Connector | Hood Pin | n/a | | Door Trigger | BLACK/ White (-) | Right of Column Gray Connector | Door Lock | BLACK/ White (-) | Gray Connector above Fuse Panel TapeD to Harness | Door Unlock | Orange (-) | | Horn Wire | GREEN/ Blue (-) | Left of Column Gray Connect |
PSALMS 37:5
Posted By: big sexy lac
Date Posted: May 21, 2009 at 11:09 PM
Ok that wire is not 4 headlamp its goes to the park lamps, h1 pin 5 get 12v constant, now h1 pin 2 goes to parking lights , if the parking lights is positive your good! But if parking lights are negative cut h1 pin1 wire and ground it.
------------- WELL?
Date Posted: May 22, 2009 at 6:21 AM
Ok folks, got it all wired up, starter disabler is working perfect. If now I can just find that dome light wire. Any suggestions?
Date Posted: May 22, 2009 at 11:17 AM
Dome light is in a brown plug left of columm (-)BLACK/ white
------------- WELL?
Date Posted: May 22, 2009 at 11:50 AM
Thanks sir!
Date Posted: June 11, 2009 at 12:34 PM
Correction, that is the negative door trigger and not the dome light wire I am looking for. Thanks tho.
Posted By: t&t tech
Date Posted: June 12, 2009 at 12:58 PM
if you're going to be doing dome supervision, then the wire big sexy lac gave you would be the wire you need.
