Hello Guys,
I have a problem with the door actuators setup. I am trying the below relay setup, but I am doing something wrong. After I connect everything the last thing I do is connect the ground to the chassis, but when I connect it I get sparks and the wire gets hot.
Why do I get a short circuit when I connect the ground???? I notice that If I don't connect the 12V to the 87 I don't get a short circuit.
Thanks a lot for your help guys
![posted_image](https://www.the12volt.com/images/actuatorrevpol.gif)
Guys, forget about this. I've found out what the problem is.
I bought this relays in AutoZne, but it seems that this relays are for some lighting applications. I verified the relay diagram and noticed that the 87 and the 87a are linked together, so that's why it was making a shortcircuit.
So if you go to AutoZne and see a 30amp relay from Federal Mogul P/N: DF005, it will not help you with the alarm applications.
Thanks for all the info you guys have here! I will try to share what I have learned here.
Hey I am having the same problem, can you tell me where u got you relays from? I got mine from Kragan. I dunno if it is the same connection where did u check it?
Thanx
240sx 92
Hey shawn240sx,
I saw in the relay diagram that 87 and 87a where linked together. This is because the relays I bougt where not SPDT.
I bought the SPDT relays from partsexpress.com they have great prices and great service. Go to that web page and click on Mobile Security, then on your right click Relays/Sockets.
Just for info, the relays sold in radioshak and autozone are not SPDT, so to be sure order them from parts express.
Let me know if you have any more questions...
shawn....you need one relay for your car....
Power Lock ORANGE / BLACK SINGLE WIRE - USES SINGLE RELAY
Power Unlock SINGLE WIRE USES SINGLE RELAY * #206
* Single Wire Door Lock System- Cut Wire,(Doors Will Lock), Switch Side To Pin #87A, Motor Side And Negative Unlock Output From Alarm To Pin #30. Negative Lock Output From Alarm To Pin #85. 12V Constant To Pin #86. Pin #87 Not Used
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Draasch
I am installing actuators and running off the alarm system's keyless entry output. The car doesnt have existing power door locks. Will what you reccomended work with my set up ? I have never heard of it done with one relay??? Is there a groud in the circuit? Let me know
Thanx
Shawn240sx
I've done a couple of cars without power locks and this is how I wired them......
you'll need 2 relays, 1 for locking and another for unlocking.
1st relay,,,,, 2nd relay,,,,,,
85 -------negative (lock) wire from alarm 85----------negative (unlock) wire from alarm
86 & 87 -------12 volt constant 86 & 87 -------12 volt constant
87a--------ground 87a ----------ground
30 ---------output to actuator ( lock position ) 30 ---------output to actuator ( unlock position)
im sorry i thought you had factory door locks. i would use two relays. what unit are you guys using???
i use the omega line and they have a DLS that just plugs right into the unit and your done.
send the info.
Good Luck
David
Ace Security
813-376-9778
Tampa
