lock with bitwriter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=114757
Printed Date: May 13, 2024 at 4:04 PM
Topic: lock with bitwriter
Posted By: Thack79
Subject: lock with bitwriter
Date Posted: June 29, 2009 at 9:42 AM
How do you lock a module (iei. python 1400) with the bitwrtier? is it a certain setting scrolling through the features?
Posted By: howie ll
Date Posted: June 29, 2009 at 12:29 PM
What are you trying to do?
Posted By: soundnsecurity
Date Posted: June 29, 2009 at 12:53 PM
it should be one of the very first options when you turn the bitwriter on
Posted By: Thack79
Date Posted: June 29, 2009 at 3:07 PM
thanks.. Dont want the options to default when they change car batteries.
Date Posted: June 29, 2009 at 3:17 PM
i dont think that replacing the battery will default the programming. the lock feature is more for making sure no one can be sneaky and program another remote to your alarm without you knowing about it.
Posted By: Thack79
Date Posted: June 29, 2009 at 3:55 PM
Just making sure. Im doing a remote start for someone no where near me and i cant get back here so I just wanted to be sure the settings dont reset if say his battery dies or something like that. and dies on the car not the remote control.
Posted By: t&t tech
Date Posted: June 29, 2009 at 3:57 PM
also just to add, dei's unite have a non volatile memory, which stores all setings, so even in the event of battery replacement the unit will still recall it's previous settings, the locking of the unit has absolutely nothing to do with this as mr soundnsecurity said.
------------- COMMIT YOUR WAY TO JEHOVAH AND HE WILL ACT IN YOUR BEHALF.
PSALMS 37:5
Posted By: howie ll
Date Posted: June 29, 2009 at 5:28 PM
The last 2 posts, by sound and security and t&t are spot on. dumping the battery won't change anything; i n fact locking the settings means a) Know one can get to them manually, you need a bitwriter, and b) someone else with a bitwriter could change the settings anyway.
Posted By: Thack79
Date Posted: June 30, 2009 at 7:49 AM
perfect thanks guys for you replies.
