alpine sec 8059 wont let me start the car
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115043
Printed Date: March 18, 2026 at 10:25 PM
Topic: alpine sec 8059 wont let me start the car
Posted By: awild
Subject: alpine sec 8059 wont let me start the car
Date Posted: July 13, 2009 at 10:43 AM
1997 Jeep Wrangler 5spd
Was "moving" the brain of the Alpine alarm yesterday without unplugging anything, honestly moved it a few inches and now I've somehow made it mad. The starter kill has enabled, the starter is getting no voltage. I've tried unplugging the battery for 20 mins. Still no start. Unplugged brain for 20 mins, still no start.
Tried the key on, flick and hold toggle, get one blink on LED, no start
Tried the key on, flick and hold toggle, get one blink, repeat to get two blinks, still no start.
Is there a way to get this thing to start?
Posted By: awild
Date Posted: July 13, 2009 at 11:59 AM
Is there a wiring method I could use to bypass the starter kill and leave everything else simply wired up? Or should I grab my Jeep manual, print off the wiring diagram for this terrible alarm, and just rip it out and rewire the jeep?
Posted By: i am an idiot
Date Posted: July 13, 2009 at 4:12 PM
You should be able to easily bypass the starter kill function. Look under the dash near the steering column, is there a relay under there? If you find the relay, there should be 2 larger wires that go from the relay and both connect to the same color wire. If you find the same color wires, simply connect them back together eliminating the relay.
Posted By: awild
Date Posted: July 13, 2009 at 4:14 PM
Thanks, I ended up trying that a few hours ago before I took out the entire alarm...needless to say neither got the jeep to start. Turns out it's not alarm related and everything seems to point to a bad ignition switch.
Date Posted: July 13, 2009 at 4:52 PM
Did you find the starter kill wires? What color was the wire. Have you used a volt meter to make sure there is not 12 volts getting to that wire? You need to verify that there is no voltage on the key side of that wire before you go and buy an ignition switch. It could be the neutral safety switch.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: awild
Date Posted: July 13, 2009 at 4:55 PM
Pulled the kill wires, spliced the two together making a bridge between the previous yellow starter wire. It has no voltage to it with key out or key in. There is very little voltage registered when I turn the key...less than 1v. The ignition wire is 12v all time. Not sure whats up.
Date Posted: July 13, 2009 at 5:46 PM
If you apply 12 volts to the yellow wire while depressing the clutch, does it turn over then?
Posted By: awild
Date Posted: July 14, 2009 at 4:08 PM
The car does not try to turn over at all. Tried putting 12v straight to that wire and still no. But I did recheck the voltage. This is the update as I wasnt getting good enough ground with my meter
I'll have to see if it's clicking at all but I replaced it with a brand new one and still got nothing.
-Getting 12v to the yellow starter wire under dash when key is turned to start (wasnt getting contact with my meter before)
-Getting 12v to the starters big cable constantly
-Had autozone check the starter and it fired right up for them
-Brand new starter relay did nothing to help it start
....clueless, and it's beautiful out and I'm just watching it sit there. Any help is greatly appreciated before I push start this and drive it to the mechanic.
Date Posted: July 14, 2009 at 4:42 PM
The only thing between the key wire and the solenoid is the clutch switch. Look for the clutch switch, it should be somewhere neat the pivot point of the clutch lever. There should be 2 wires going to that switch. If you can unplug the plug from the switch and short the 2 wires together, temporarily and see if it turns over. It will start in gear while in this condition. So be very careful when checking this.
Posted By: awild
Date Posted: July 14, 2009 at 5:19 PM
Ended up that there was some type of interruption between the starter wire under the dash and the wire to the starter solenoid. I simply jumped into the good wire under the dash and fed it straight to the solenoid.
Thanks for all those that helped along the way. This issue made me find this forum and I'll be sure to keep coming back with all my great electrical issues lol.
