2009 chrysler 300 need diagrams
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115143
Printed Date: June 10, 2024 at 10:21 AM
Topic: 2009 chrysler 300 need diagrams
Posted By: stevetolentino
Subject: 2009 chrysler 300 need diagrams
Date Posted: July 17, 2009 at 2:26 PM
Can anyone help me? I need some wiring info for installing a basic alarm. Most important is where to hook up a starter kill on this vehicle. Thanks for the help, I will need this before Saturday Morning.
Posted By: profuse007
Date Posted: July 17, 2009 at 3:41 PM
search for 2008 chrysler 300 if it's the same generation body and engine.
I would do ignition-kill instead, the starter wire might under the hood.
------------- Houston,TX
Posted By: i am an idiot
Date Posted: July 17, 2009 at 4:19 PM
From a liability standpoint, I STRONGLY recommend NOT doing Ignition kill on this or any other vehicle. If there is a failure of a relay or wiring on a starter kill, the car will simply not start. It you do Ignition kill and the same failure occurs while pullling out in front of a tractor trailer, well that could be much worse than having a customer stranded somewhere.
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Date Posted: July 17, 2009 at 5:00 PM
I agree, I never do them that way. Anyone else have a wiring chart???? HELP!
Date Posted: July 17, 2009 at 5:09 PM
Not sure why y'all think it's bad idea. I understand the situation b/t starter and ignition-kill. however, the same concept can be applied onto main relay or newer vehicles w/ ignition relay that use low-voltage switching. and those relays are always energized.
I do not do ignition-kill or fuel-cut but there is nothing wrong w/ the method.
if you believe a high probability that the relay can turn itself on or other related failure, you should stop using relays altogether.
steve, did you make the search yet?
Date Posted: July 17, 2009 at 5:17 PM
No not for a 2009, I've checked out all the 2008 and previous years but I'm not sure if it changed in 2009.
