2004 pontiac grand prix
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115332
Printed Date: May 08, 2024 at 7:08 AM
Topic: 2004 pontiac grand prix
Posted By: grasshoper420
Subject: 2004 pontiac grand prix
Date Posted: July 28, 2009 at 8:38 AM
hello i bought a 2004 pontiac grand prix it came with a remote starter and alarm well first the remote was not working right so i stoped useing it and i would just look the doors buy useing the one s in side the car now when i do that i use my key to unlock my car and my alarm go s off every time i unlock it and i have a hard time shutting it off just wondering what i should do could some one tell me were i could find where the man computer for my remote starter could be found and has any one had this problem the model of the remote starter is auto mate 6 any help with this would be great thank s for your time
peace grasshoper420
Posted By: Chris Luongo
Date Posted: July 28, 2009 at 9:09 AM
It's hard to understand what you're saying without any puncutation in there, but I think I got the general idea.
Automate AM6 is only a remote starter with keyless entry, it's not an alarm.
The lower plastic panel on that car, the one that's above your feet....I think it's just three clips you can pry out and the panel comes right off, you might want to look under there with a good light and see if it's an AM6 or something else.
Date Posted: July 28, 2009 at 11:31 AM
well thank s for the info but i got it it had to be reprogrammed witch i did and now it is working well if dont have an alarm then why dose it go off when i go in to it ? then my manual is wrong then there must be a nother model in my car then because i roll down my window i arm it then i unlock thro the window and then open my door and the alarm go s off beep beep beep what would that be then but any ways i got it working again what i had to do was fine the valet switch push it down five time and on the 5 time push the button's on the remote and then you reprogrammed it oh ya your car has to be on but not started .
peace grasshoper420
ps thank s for the info
Date Posted: July 29, 2009 at 12:02 PM
okay like i said i got it programed but about one hour after it stopped working i did the same steps again and it worked but then again it stopped i think that i meaning me need to get it to save or out of programing dose you no how to do that ?
Date Posted: August 03, 2009 at 7:44 AM
hello you there
Posted By: soundnsecurity
Date Posted: August 03, 2009 at 8:32 AM
is it the car's horn that goes off or does it sound like a alarm siren?
Date Posted: August 03, 2009 at 8:41 AM
just the horn
Posted By: richl68
Date Posted: August 03, 2009 at 9:25 AM
factory alarm? or its a different model and they just tied the siren into the horn instead of mounting a siren.
Date Posted: August 03, 2009 at 10:46 AM
it is a am6 so just the horn but i was trying to program it and now it say s reduced engine power i think i i messed it up now i dont no what to do it still start s but it says that now reduced engine power
Date Posted: August 03, 2009 at 11:31 AM
okay i reset it with my obd 2 reader and that when away but still no remote start or unlock i pulled my dash a part and looked at the module or what ever it s called and it is a AM6 so i need to still program it so if any one could help me out that would be great thank s
Date Posted: August 03, 2009 at 12:19 PM
what is this place for if no one help u
Posted By: richl68
Date Posted: August 03, 2009 at 1:05 PM
Everyone isnt sitting at the computer looking at "your" topic waiting for you to respond...the best thing i can say is go on the manafactuers website and see if you can get a programing manual. should have a step by step on how to program the features of the remotestart.
Date Posted: August 10, 2009 at 8:28 AM
thank s i no that there not sitting around waiting for me to reply but it has been oh i dont no how long some one say s one thing i reply they never say any thing back or they tell me i dont have what i say i have but what ever im looking around other site s to get my answer i guess
peace
Posted By: mike swanson
Date Posted: August 10, 2009 at 1:57 PM
If you lock your door from the inside switch then shut the door. That is what sets the factory alarm.
So then you unlock it with the key and the horn goes off,,,,Right?
That would be the factory alarm. The wire that goes to ground when you turn your key is not working.
Also most of the gnd prix cars were done with a key in a box. If you got it used the key in the box is prolly gone. if it wont remote start
Try puttn the key in the ign and then remote start the car. if it stays running then thats what is wrong
Date Posted: August 10, 2009 at 2:00 PM
Im sure your key says PK3 on it
If you have the computer screen on your dash by the vents, then it prolly was done with a key in a box OR the key was just sittn behind the plastic next to the key ign
Some installers did this to keep the correct date and time on the computer screen
Date Posted: August 11, 2009 at 7:49 AM
okay yes it say s pk3 on the key what dose key in the box mean ? the thing is that the remote dont work at all i cant unlock or lock the car or start it i need to program it and i cant seem to do that i took it to a dealer and they dont look at after market stuff and i cant seem to find any one to look at it the dealer want s me to [put a 400 dollar unit in well im not unless for sure mine is broken
Date Posted: August 13, 2009 at 5:52 PM
Sorry thought that it was working, but wont remote start
Date Posted: August 14, 2009 at 8:51 AM
Probably most of us are having difficulty reading/understanding your posts, because there seems to be no capitalization or puncutation.
But, as near as I can tell, it seems like you have two separate problems:
1. Unlocking driver's door from the outside, with the key, does not disarm the factory Pontiac alarm.
There's a setting for this in the programming menu in the driver information center, above the radio.
The owner's manual should explain how to change the features.....but you want to turn that feature back on, to avoid having the alarm go off in the future.
2. AM6 remote start doesn't work. You said it no longer locks or unlocks the doors, or remote starts the car......but does it do anything at all? Does if flash the lights? Make clicking sounds under the dash? Anything?
Most shops will only want to replace it, rather than repair. It usually takes forever to dig into someone else's install, and then we'll "inherit" any future problems with the system as well.
However, you could probably find an install guide for the AM6, and with some basic tools to disassemble the car, as well as a test light and/or multimeter, go and test each wire going to the system one by one, and hopefully find where the problem is.
Date Posted: August 15, 2009 at 12:54 PM
Are you sure??
A Light Green wire in the driver door boot should disarm the factory
This wire is tied to the unlock from outside
This factory alarm has 4 modes you can set it for
Date Posted: August 30, 2009 at 4:59 PM
I meening me need help with my auto mate 6 need to reprogram it it dose not work at all it s a xcrs
Date Posted: August 30, 2009 at 5:01 PM
Are you sure??
i dont care about the factory alarm i need my AM6 working
Posted By: tommy...
Date Posted: August 30, 2009 at 5:22 PM
Dude...I started to try to help/read.your posts...But as someone else said...WHAT>>>! If you do not have enough respect to read the rules and follow them...Why should anyone here take there time to help...?! It is like one super long run-on sentence...Slow down and take your time w/ the questions...I would bet a plethra of responses follow...!
------------- M.E.C.P & First-Class
Date Posted: August 30, 2009 at 7:02 PM
you no what you all can go f#$k your self s this site suck no one help any one but i bet you can under stand this run on sentence cant you hehe
Date Posted: August 30, 2009 at 7:03 PM
Date Posted: August 30, 2009 at 7:05 PM
Read and follow all of these rules before posting!
Help us help you, and in the process help everyone else by following these simple rules.
• Do not create a new topic for each part of your installation or duplicate topics. Duplicate topics and multiple topics about the same installation will be deleted. Please continue posting in your existing thread.
• Make sure you are posting in the correct forum.
• Do not type any words in all caps in your subject and keep them to a minimum in your message. In other words, Kill the CAPS!
• Do not include any of the following words or phrases in your topic subject: help, help please, install, installation, question, questions, Q's, install help, install questions, please, plz, assistance, or any other vague word or phrase. Be specific and informative.
• Do not use excessive punctuation or special characters in your subject. One question mark is enough.
• Include the year and model of vehicle and model or type of equipment if applicable in your subject.
• Be as informative as you can in your message and use punctuation in your message.
• Do not add images over 640 pixels wide.
• No Spam! All spam will be deleted and your membership will be immediately suspended.
Failure to follow any of these rules may result in your topic being deleted and the suspension of your membership without notice!
DUDE READ THIS you broke some of the these your self
