best way to convert positive to negative?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115510
Printed Date: May 15, 2024 at 10:12 PM
Topic: best way to convert positive to negative?
Posted By: rodriik
Subject: best way to convert positive to negative?
Date Posted: August 06, 2009 at 9:25 PM
What is the best/simplest way to invert from + to -?
Posted By: i am an idiot
Date Posted: August 06, 2009 at 9:27 PM
Convert a Positive Output to a Negative Output | If you have a switch or an alarm or keyless entry that has a positive output that you wish to use to switch a device that requires a ground such as a horn, dome light, parking lights, head lights, hatch release, etc., wire a relay as shown below to convert the positive output (trigger) to a negative output. Here's the same configuration showing a positive output from an alarm or remote keyless entry used to activate a vehicle's parking light relay that requires a ground to turn the lights on. |
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: rodriik
Date Posted: August 06, 2009 at 11:34 PM
Thanks. What's the best way to do it without a relay? This is in the cab and I don't want the clicking noise.
Posted By: racing_bidule
Date Posted: August 07, 2009 at 12:51 AM
GET A WIFE! LOL ------------- If you fail on your first attempt, at least destroy all evidence you tried!
Posted By: howie ll
Date Posted: August 07, 2009 at 3:56 AM
That last post was a classic, second, Mr. Idiot "ex master installer" what's the way to do it using transistors please, ie pos to neg and vice versa? Email me if you can't post it here.
Date Posted: August 07, 2009 at 8:00 PM
Howie, the things that you remember me posting were simple current amplifying devices. They are used for bluetooth modules that do not have enough current capacity to trigger a relay. Also used in some newer databus cars. There is sometimes not enough current to get an ignition source. If you connect a relay to the wire at the ignition switch, it freaks the car out. I do not know of a simple way to convert polarity with a transistor. I will make a call and see what I can find out for you. ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: OmarR
Date Posted: August 09, 2009 at 10:36 PM
Wouldn't it be easier to just mount the relay in the engine compartment and run the output wire into the cab?
Posted By: darksidecelica
Date Posted: August 10, 2009 at 8:31 PM
Hmm. I thought only relays can convert a + to a -.
