add on sensors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=115698
Printed Date: June 08, 2024 at 4:29 AM
Topic: add on sensors
Posted By: kease
Subject: add on sensors
Date Posted: August 17, 2009 at 1:23 PM
i have the viper 5900 with remote start, audio sensor, tilt sensor and a dual stage prox sensor. my installer told me that he just grounded these sensors instead of using the ground when armed wire. is this the right thing to do? and does he need to use diodes? thanks for any help anyone can give me ------------- Kease
Posted By: howie ll
Date Posted: August 17, 2009 at 1:26 PM
It makes no real difference except I would join them together with diodes on the blues AND greens (bands towards the sensors) and plug them into the alarm's sensor socket, then it's using the correct GWA from the socket.
Posted By: t&t tech
Date Posted: August 17, 2009 at 6:25 PM
True, it makes no real difference, but all the addons would be on constantly and triggering as well, except if the alarm isn't armed he won't know, they'll be on even whilst driving,
Posted By: JWorm
Date Posted: August 17, 2009 at 7:51 PM
The tilt sensor calibrates the angle of the vehicle when you arm the alarm and it receives ground on the ground when armed input. If it is wired straight to ground, it is not working at all.
It would also help if you listed the model of the tilt sensor. I know DEI has made a couple similar models over the years.
Posted By: kease
Date Posted: August 17, 2009 at 9:19 PM
the tilt sensor is a 507M, the audio sensor is 506t and the prox os 508D
------------- Kease
Posted By: JWorm
Date Posted: August 17, 2009 at 10:13 PM
From the install manual for the 507m:
IMPORTANT In order for the 507M to learn the inclination angle each time the vehicle is
parked, the ORANGE wire must be connected to a security system ground-when-armed output or to an acceptable switched ignition ground reference wire.
Its not really important what the "ground" wires go to on the 508d or 506t. Connecting all 3 to the same GWA circuit would probably be more current than it is designed to handle. Boosting the output with a relay would not work either, because you would kill the vehicle's battery. Don't worry if these were wired directly to ground.
Posted By: howie ll
Date Posted: August 18, 2009 at 1:57 AM
Just to make another point, you've too many sensors, they will interfere with each other unless diligently set up, all you really need is a prox sensor, the 507m is more reliable than the older 507t but make sure it's mounted on a solid surface. Usually unless the 506t is turned down so much that it's unusable, the outer zone of the 508d can trigger it.
