ford ranger doors
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11601
Printed Date: May 16, 2024 at 10:35 AM
Topic: ford ranger doors
Posted By: quik525420
Subject: ford ranger doors
Date Posted: March 29, 2003 at 9:42 AM
hello, I got kind of a strange problem here, I have a 2000 ford ranger that at random times the door open light will come on and you hear the chime for it, even when the doors are closed, It happens when I am driving and nothing I do seems to turn it off (opening and closing the doors). It has an alarm on it and it goes off randomly I believe because the alarm thinks the door has been openend when it hasn't, my question is what would cause this? I don't see any switches for the doors so I am assuming that they are in the latch? anyone ever heard of this. it is weird. thanks for any help
Posted By: scuba1954
Date Posted: March 29, 2003 at 8:51 PM
You are right about the door switches being in the latches. Take some WD-40 and spray the drivers door latch really good, probably have picked up some moisture in it. This is a very common problem with the rangers.
Posted By: draasch
Date Posted: March 30, 2003 at 9:50 AM
scuba has hit the nail on the head........always use WD40 nothing else like grease. WD40 will take care of any miosture that might be in there and also lube it. ------------- Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: March 30, 2003 at 2:12 PM
thanks I will try that and let you know what happens
