2010 Mazda 3 Remote Starter Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116276
Printed Date: April 29, 2024 at 5:44 AM
Topic: 2010 Mazda 3 Remote Starter Wiring
Posted By: mi99z71
Subject: 2010 Mazda 3 Remote Starter Wiring
Date Posted: September 12, 2009 at 12:48 PM
Anyone have a wiring diagram for remote start wiring for a 2010 Mazda 3. And also what bypass module would one recommend to do this? Thanks Norm
Posted By: tommy...
Date Posted: September 12, 2009 at 2:37 PM
Posted By: tommy...
Date Posted: September 12, 2009 at 2:38 PM
Posted By: tommy...
Date Posted: September 12, 2009 at 2:39 PM
| Headlights-Lo | | BROWN | | (-) | | BCM MODULE...ALSO AT LIGHT SWITCH HARNESS | | | | All Hazrd Lights | | WHITE | | (-) | | BCM MODULE | | | | Parking Brake | | VIOLET | | (-) | | BCM MODULE | | | | Trnk Release | | BROWN | | (-) | | BCM MODULE | | |
------------- M.E.C.P & First-Class
Posted By: tommy...
Date Posted: September 12, 2009 at 2:41 PM
Does that have the Smart-Key...? Flash-it.com will tell you what bypass yo use...! FLCAN...FLTB1...FLTBF...Are a few w/o SmartKey...
Posted By: dennis f
Date Posted: September 21, 2009 at 2:21 PM
If this car doesn't have the smart key, can I use a ASTCBM or equivalent and just wire everything else up or is there a better option with a module?
My customer has 2 keys (both with the built in keyless) and some kind of chip or something on a card I have not seen yet.
What are my options?
------------- -Dennis
Posted By: cdm_sd02
Date Posted: September 29, 2009 at 6:46 AM
Thanks for the INFO
Posted By: mi99z71
Date Posted: November 09, 2009 at 8:09 AM
Having a slight problem with install. Just can't get bypass it work. Using a xpresskit, xk05 with pkti firmware flashing. I can't seem to get module to program. Just wanted to see if any one could verify colors for the TX and RX wiring. When I wired it all up, all the module did was LED was on, then I inserted first key and turned to on position, then led flashed, and came back on. So I switched keys, and tried to program second key, and the LED just stayed on. There are 4 wires at the connector ( dark blue, light blue, black, and orange ) in those colors. Otherwise, module directions state to reset module if it won't program. which in this case involves reflashing it. And I have not don't that part yet. Thanks Norm
Posted By: jordan_lin
Date Posted: March 27, 2010 at 1:28 PM
Hi there, I am having problem finding the door pin signal on this car. can anyone help?? Thank you
Posted By: tedmond
Date Posted: March 27, 2010 at 9:37 PM
for the bypass there is a 4pin plug at the ignition cylinder. TX - grey/orange RX - WHITE/ light green
leave your gwr or status wire unhooked until you are done programming. For the thread highjacker, use 4 diodes to diode isolate the wires. diode band towards wire on car. LF - BLUE (-) @ BCM plug F Pin G RF - GREEN (-) @ BCM plug F Pin H LR - BROWN (-) @ BCM plug F Pin E RR - ORANGE (-) @ BCM plug F Pin K ------------- Ted
Compustar Expert
Posted By: robtrevino
Date Posted: November 21, 2010 at 9:53 AM
Is the pinout available? There a alot of wires with the same color.
Posted By: howie ll
Date Posted: November 21, 2010 at 10:17 AM
That's where your DMM comes in handy.
Date Posted: November 21, 2010 at 11:39 AM
Beg your pardon, What is DMM? Anyway, does anyone have the pinout? Or a schematic I can look at?
Posted By: howie ll
Date Posted: November 21, 2010 at 12:24 PM
If you don't know what a DMM is don't attempt it.
Posted By: wireaudio
Date Posted: December 18, 2010 at 4:05 AM
So i wanted to add to my alarm automatic rollup and rolldown using two aux channels. (My alarm has 4-5 or so aux channels).
Problem is, i'm not quite getting it how the window controls work. What is (AC) polarity mean? Alternating Current?
Thanks in advance!
Posted By: howie ll
Date Posted: December 18, 2010 at 4:32 AM
First, it's extremely rude to jump in on some one else's thread, do you even own a Mazda?
Second, I've sworn never to answer a post beginning with "So I".
Third, AC????.
Start your own post, list the vehicle, R/S used and window closer you've chosen and we will try to advise you.
Date Posted: December 18, 2010 at 1:49 PM
1. I thought this was the remote starter wiring thread for mazda 3. I am installing a remote starter with alarm on my 2010 mazdaspeed 3.
2. If you don't like it dont answer it, you dont have to be rude for me asking a question. My car's taken apart in a garage right now and i cant put it back together until i finish this wiring, and i need the car on Monday.
3. AC comes from the previous page where it's saying that the polarity on the window wiring is (AC). (But if you would have actually read the previous page thread you would know.)
LF Window Up |
WHITE/ BLACK |
(AC) |
MASTER WINDOW SWITCH |
LF Window Dn |
WHITE/ GREEN |
(AC) |
RF Window Up |
ORANGE |
(AC) |
RF Window Dn |
LIGHT BLUE |
(AC) |
LR Window Up |
WHITE |
(AC) |
LR Window Dn |
VIOLET |
(AC) |
RR Window Up |
GREEN |
(AC) |
RR Window Dn |
VIOLET |
(AC) |
MASTER WINDOW SWITCH | "
that's what tommy... posted in there.
Any ideas anyone?
Posted By: tedmond
Date Posted: December 18, 2010 at 9:36 PM
wireaudio, first off its wrong to hijack someones thread.
start your own. and the windows are Type A, positive switched. ------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: December 19, 2010 at 9:09 AM
wireaudio since you insist on crashing some one else post off topic, AC is technically incorrect. They aren't AC they simply reverse polarity.
The wires listed in a type A set up (which is the set up for about 90% of window switches) simply as an example, the WHITE/ black and WHITE/ green sit on ground at rest. When the switch is moved to the up position WHITE/ black becomes 12v+ and WHITE/ green stays at ground.
Your window lifters well cut in at these points.
