code alarm pro 1000sx wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116278
Printed Date: May 16, 2024 at 10:32 AM
Topic: code alarm pro 1000sx wiring
Posted By: shoult
Subject: code alarm pro 1000sx wiring
Date Posted: September 12, 2009 at 3:14 PM
I did a stupid thing. I purchased a used 92 Mazda Miata in July (That's Not the stupid part!). I found out it had a non-working Code Alarm Pro 1000sx (I'm sure you can see where this is going already). It no longer chirped, flashed or sirened. I decided I wanted to remove it. I squeezed my overly large body under the dash and proceeded to unhook the brain box with abandon. Of course the car no longer starts and I have NO idea how to hook it back up. There is no wiring diagram on the back of the box and Code Alarm won't answer their phone until Monday.
Besides the three multi-pin plugs (which are reconnected) there are red (fused), black, white and WHITE/ red wires that need to be reconnected. There is also a purple with that has no connector on it and looks as if it never did. There are 7 lugs that these wire could be attached to.
I need help! I am taking this car on a long trip Wednesday and still need to do some minor work on it before I leave.
Posted By: jim hunter
Date Posted: September 13, 2009 at 11:46 AM
the white and the WHITE/ red should be the starter wires (which have been cut to run thru this KILL switch connection) tie them together and the car should start with everything else disconnected
Posted By: shoult
Date Posted: September 13, 2009 at 2:37 PM
Thank You! Thank You! Thank You!
With that little bit of information as a safety net I have been able to test, confidently remove, test, remove some more, test, remove it all and test again.
The Code Alarm has now been given a (not so) decent burial and the underside of my dashboard is much cleaner for it!
Once again Jim, THANK YOU!
