viper 5101
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116601
Printed Date: May 09, 2024 at 12:30 PM
Topic: viper 5101
Posted By: beder1
Subject: viper 5101
Date Posted: September 29, 2009 at 2:31 AM
Was wondering if anybody could help me out with the vehichle specific wiring diagram for a 2003 Pontiac Sunfire. It has 2.2L eco-tech 4 cylinder engine. I bought the Viper 5101 One way remote start and car alarm.
Posted By: chev104275
Date Posted: September 29, 2009 at 5:23 AM
Security
WIRE COLOR POLARITY LOCATION
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger
YOU MUST DIODE ISOLATE BOTH TRIGGERS TO MONITOR ALL DOORS. *SEE DOCUMENTS
LF Latch LIGHT GREEN/ BLACK (-) AT THE BCM
RF Latch LIGHT BLUE (-) AT THE BCM
LT.BLUE COVERS THE PASSENGER'S DOOR AS WELL AS THE REAR DOORS
Trunk Trigger ORANGE / BLACK (-) AT THE BCM
OR BLACK AT THE LIGHT IN THE TRUNK.
Alarm Disarm RF ONLY
Alarm Arm RF ONLY
Parking Lights BROWN (+) AT VEHICLE LIGHT SWITCH OR THE DRIVERS KICK PANEL
Convenience
Headlights-Lo DARK BLUE (-) AT VEHICLE LIGHT SWITCH OR BCM
LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb BROWN (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb BROWN (+) AT REAR RIGHT PARKING LIGHT
Wipers-Lo DARK GREEN (+) AT VEHICLE WIPER SWITCH
Trnk Release BLACK/ WHITE (+) AT THE BCM
Remote Start
Ignition 2 WHITE OR GREEN (+) IGNITION SWITCH HARNESS
Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS
Accessory 2 BROWN
Anti-Theft Type PASSLOCK II
Anti-Theft Descript A RESISTANCE BASED SYSTEM
Key Sense LIGHT GREEN (-) IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) IN CHASSIS HARNESS NEAR BATTERY
OR A VIOLET/WHITE IN THE ENGINE HARNESS THAT RUNSNEXT TO THE BATTERY, BELOW THE RADIATOR HOSE, JUST ABOVE THE TRANSAXLE.
Speed Sense DARK GREEN / WHITE (AC) IN LARGE BLACK PLUG NEXT TO LEFT SHOCK TOWER
Brake Lights WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights LIGHT GREEN (+) DRIVER'S KICK PANEL IN HARNESS RUNNING TO REAR
Horn BLACK (-) AT STEERING COLUMN HARNESS OR AT BCM
Modules
WIRE LOCATION
Module 1 BCM - BODY CONTROL MODULE IS LOCATED HIGH IN THE DRIVERS KICK PANEL
Doorlocks/Windows
Power Unlock WHITE (+) AT THE BCM
VEHICLES WITHOUT OEM KEYLESS ENTRY WILL BE (REV).
PowerLock LIGHT BLUE (+) AT THE BCM
------------- If i Can't Install it I Don't need it Joe
Posted By: xtremej
Date Posted: September 29, 2009 at 8:55 AM
viper 5101 is remote start only.
Posted By: beder1
Date Posted: January 09, 2010 at 5:19 AM
I meant the Viper 5601
