avital 4103l programming
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=116999
Printed Date: May 13, 2024 at 9:53 AM
Topic: avital 4103l programming
Posted By: arcanemirage
Subject: avital 4103l programming
Date Posted: October 16, 2009 at 12:39 AM
I took the advice from people on here and had my avital remote start system installed professionally. Now, as I try to follow the instructions to program different features, they don't seem to work. I bought the Avital 4103L 1-button system. Is it possible to program other remotes to the system (i.e. 2 or 4 buttons)? Thanks for all your help!
Date Posted: October 16, 2009 at 3:49 PM
I wrote that wrong...its actually the 4113L. Sorry.
Posted By: xtremej
Date Posted: October 16, 2009 at 3:50 PM
what features are you trying to program? Why not have the dealer who installed program these festures? They can do it in minutes with a bitwriter.
Posted By: Twelvoltz
Date Posted: October 16, 2009 at 5:02 PM
The bitwriter can lock out the ability to manually change settings, requiring a bitwriter be used in the future. They probably activated the 'lockout' option when programming the options originally. ------------- Installer, IT support, and FFL. I need less hobbies.
Date Posted: October 16, 2009 at 5:21 PM
I took it down to Car Toys to see if they could unlock it but it didn't work. The installer did not use a bitwriter on it. Can it still be locked? I did notice in the manual that if you hook up the bitwriter, you have to unplug the heavy gauge wire cluster while doing it? Is this true?
Date Posted: October 16, 2009 at 5:33 PM
Sorry I forgot to answer your question..I'm trying to program my doorlocks to lock when I turn the key on and unlock when I turn it off.
Date Posted: October 24, 2009 at 6:49 PM
Ok, there are 2 menus for the Avital 4113L but one button. How do I select which menu I want?
Posted By: dasbogie
Date Posted: October 24, 2009 at 9:54 PM
Did they hook up the door locks when they installed it?
Posted By: jim hunter
Date Posted: October 25, 2009 at 4:13 PM
if its a 1 button start only they have nothing hooked up to the door locks so theres no door lock programming you can do, the locks are only being controlled by your factory fob
