looking for a nice button switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=117422
Printed Date: May 19, 2024 at 3:55 AM
Topic: looking for a nice button switch
Posted By: number2
Subject: looking for a nice button switch
Date Posted: November 02, 2009 at 2:34 PM
I need a nice small discrete on/off button. I'm installing it on the plastic u-shaped panel under my stereo so a rocker switch might work if it is really soft. 1-3 amp should do it. Searching around I can't find much but big, bulky ugly crap that will stick out.
Any suggestions are appreciated.
Posted By: brhaugen
Date Posted: November 03, 2009 at 5:48 PM
get a micro toggle - havem at radioshack
------------- Brent Haugen
Fargo, ND
Posted By: number2
Date Posted: November 04, 2009 at 3:48 PM
Those are cool. Id rather have a small black button that sits flush to match the panel. With green LED illumination would be awesome but not really necessary.
Posted By: Mike M2
Date Posted: November 04, 2009 at 3:59 PM
We use these at work for anything we use a switch on. Easy to install and they look good... https://www.oznium.com/rocker-switch ------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: number2
Date Posted: November 04, 2009 at 5:29 PM
Do they take a lot of pressure to push on or off? The panel im mounting to is old and im kinda afraid it might cracking or break.
Posted By: Chris Luongo
Date Posted: November 05, 2009 at 9:08 AM
https://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=491&Cfid=2827554&CFTOKEN=43565340
Here are some interesting pushbutton switches. If you're looking to turn something on, leave it on for a while, then turn it off, make sure NOT to choose a "momentary" switch.
Here's another switch I've always loved the look of, but I've never come across an application where I've needed it. You can get it at AutoZone too.
https://www.autobarn.net/plsw16.html
P.S. If you're worried about your brittle dash panel, I wonder if you could reinforce the backside of it. Maybe get a piece of thin but sturdy plastic, cut it to shape, epoxy it to the backside of the panel.....then drill through both pieces and mount your switch. Make sure the piece of plastic isn't too thick for the switch to pass through it.
Posted By: number2
Date Posted: November 05, 2009 at 10:00 AM
I just measured realized I only have room to have about 15mm or smaller button. So that throws out any rocker switches or almost anything I have seen. There is this one
https://www.parts-express.com/pe/showdetl.cfm?Partnumber=060-620
But its for 120VAC. Will it still work?
