2007 silverado data wire gone?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=118069
Printed Date: May 29, 2024 at 4:22 PM
Topic: 2007 silverado data wire gone?
Posted By: cazador
Subject: 2007 silverado data wire gone?
Date Posted: November 28, 2009 at 11:32 AM
I am installing an alarm on a 2007 chevy silverado. It had a factory alarm by Karr. I removed it and plugged my wires into it. my only problem is that it asks for the XK01 by expresskit with 4.00 firmware. I have all of that but you have to hook it up to the violet wire in the obdII scanner plug...However, the violet wire is not there! So where am i supposed to hook up the xpresskit to? or is there another way to hook up the doorlock directly without the kit. Please let me know ASAP! thank you very much
------------- No Limit Sounds 24320 Sunnymead Blvd, Moreno Valley Ca
Posted By: Mike M2
Date Posted: November 28, 2009 at 12:12 PM
Is this a classic? They made both in 2007, but only the classic is purple. The new body style the data wire is green in pin number 1 at the OBD2 connector...
------------- Mike M2
Tech Manager
CS Dealer Services
